What's the difference?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by swta, Jul 12, 2002.
  1. swta
    swta Registered Member
    Jul 7, 2002
    5
    What\'s the difference?
    Hello All,
    What's the difference between '73-'86 and '87-'91 K-5 motors, other than the TBI? I'm looking to purchase a dual exhaust kit for my '86 K-5, but the Flow Master exhaust kits are only for the '87 and later trucks. Is the difference in the '87+ heads, or is it a difference in frame / chassis? Basically my question is....Will the '87 and later Flow Master kit fit an '86 and earlier K-5?
  2. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    Re: What\'s the difference?
    '86-'91 motors basically have different sealing issues resolved. One piece rear seal, centerbolt valve covers, different center intake bolts, etc. My only guess would be the transfer case. In '87 I believe the switched to the NP-241 transfer case, along with a different crossmember. I doubt that minor detail would hold things up though.
  3. 95 Silverado
    95 Silverado 1/2 ton status
    Nov 9, 2001
    467
    Central PA
    does it list the kit for a truck, or specifically for a k5 Blazer. the 73-87 trucks and blazers shared the same front frame and driveline, after 87 the trucks went IFS and the driveshaft moved to the left side while the blazers stayed the same. consequently 88 and later truck parts don't fit blazers of the same years.
  4. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    '87's still had 208s. I think the case was changed in 89 or 90.
  5. swta
    Jul 7, 2002
    5
    The kit P/N 17161 is specifically for the '87-'91 K-5 Blazer...not P.U.
  6. 95 Silverado
    Nov 9, 2001
    467
    Central PA
    GM began fuel injecting the engines (TBI) in '87 (I think) that kit could have the provisions for the o2 sensor where the earlier kit would not, but the later kit would probably still be usable on the older trucks.
  7. swta
    Jul 7, 2002
    5
  8. trailblazer87
    trailblazer87 1/2 ton status
    Jun 11, 2002
    707
    Madera, CA
    87 is the first year of the tbi, chevy changed heads in that year, so anything prior to that won't seal right. Other than that its the same front to back.
  9. dyeager535
    26,975
    I don't think thats correct. Only difference should be the intake manifold pattern on the heads. I've got a pair of TBI exhaust manifolds here if I need to measure anything. I believe the O2 bung would be the only difference.
  10. trailblazer87
    Jun 11, 2002
    707
    Madera, CA
    If thats it then just cut a hole and weld a ring for the sensor on and go.
  11. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    I have read the whole thread and just about everything covered here is listed right here .
