What's the difference
Discussion in 'The Garage' started by Z3PR, Jan 26, 2003.
  1. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    What\'s the difference
    What's the difference with a U-joint and a CV-joint ????? Is one stronger then the other ???? If CV-joints are better, could I run all CV's instead of U's ???
  2. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    Re: What\'s the difference
    when people on here talk about CV joints they are usually refering to a double cardan, which I dont think is really a 'CV' but is commonly called 'CV'
    maybe one of the experts will chime in and correct me
    CV joints usually have several large balls, captured grooves, between an inner and outer cage
  3. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    m j is right on the technical differences. What's that car you got, look at the front end on the inside of the wheels, the rubber acordian type boots you will see is what a CV joint really is. The description that m j gave is what you will be seeing if the rubber boot ain't on there.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Here's a link to a page that explains it for you. /forums/images/graemlins/cool.gif http://www.tpub.com/basae/117.htm
    A double cardan joint is a constant velocity design. There are several variations of CV joints. The double cardan is just one of them.
  5. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I'm talking about in the driveshafts and in the front axle on a K5. Okay, I may not have the right name of the joints, but I'm sure you'll know what I'm talking about.
  6. Bubba Ray Boudreaux
    Jan 21, 2001
    20,716
    We know what your talking about. I think there is a post from maybe a month ago that had some CV tech for the rear shaft.
