Whats the diffrence?
Discussion in 'The Garage' started by hunterguy86, Oct 15, 2005.
  1. hunterguy86
    hunterguy86 1/2 ton status
    Jan 10, 2005
    2,477
    San Marcos, Texas
    Hey I know this is a stupid newbie question. However Im trying to learn all I can. So what is the diffrence between a roller cam and a flat tappet cam? And whats the diffrence between roller rocker arms and regular rockers?
    Sorry this is dumb but please enlighten me.
  2. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    regular scuffs against the lobs or valve tip. rollers roll on a bearing over the lobes or valve tips. rollers offer less friction and wear on items. and also give free hp to motor and rev just a bit faster.
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    The lifters on a flat tappett are normal looking lifters , flat on the bottom where the cam touches it . Lifters on a roller cam have rollers on the bottom where cam touches it .
    Rockers are stamped steel stock , and its metal to metal on teh fulcrum point and valve stem tip .
    Cheap roller rockers are still stamped steel in the fulcrum point , but roller tip on the valve stem , creates less friction .
    Real roller rockers have a roller fulcrum , roller tip , and vrtually no friction .
    Which makes some power , is closer to its rated ratio than stamped steel , and lasts longer
