What's the easiest way of cutting down H1 magnesium runflats?
Discussion in 'The Garage' started by ankarback, Jan 1, 2007.
  1. ankarback
    ankarback 1/2 ton status
    Oct 8, 2002
    294
    Huddinge, Sweden
    I now someone here used a bandsaw to cut them down but that's not something that I have access to. Can it be done with ordinary handtools?
    Anyone know if they really are magnesium or if they are some kind of alloy? Good to know since you have to cool down magnesium when cutting it.
    I'm just considering what to do about them since they seems a little bit too big to just leave them as they are and changing to PVC insert might be more work than cutting the existing runflats.
    Any suggestions?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    changing to PVC inserts more work? THe hardest part of changing to pvc inserts is puting them in the tire. Cutting the runflats with hand tools will take HOURS upon HOURS.
  3. kgblazerfive
    kgblazerfive keymaster Premium Member GMOTM Winner
    Dec 2, 2004
    10,609
    602
    Hooper, Utah 84315
    Get out a torch and cut them off:eek1:
    Then put on dark glasses and watch the magnesium burn through anything that is near it, it will be like the 4th of July :D :haha:
  4. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I used a sawzall with a Lennox blade and it ut like butter. Then I touched up the cuts by grinding the edges smooth with a 60 Grit flap disk
    And yes they are really magnesium
  5. readymix
    May 30, 2004
    6,706
    26
    The end result
  6. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    Thanks readymix that's what i was thinking about doing. Looks great !
    Now I know it is possible to do. Perhaps I should have written electrical handtools :)
    Did you use anything to cool the runflats down while cutting? As stated above you don't want it to catch fire. Burning magnesium is not nice:doah:
  7. readymix
    May 30, 2004
    6,706
    26
    It takes quite a bit of direct heat to light a solid piece of it. Just keep brushing the shavings off and you will be fine.
  8. ankarback
    Oct 8, 2002
    294
    Huddinge, Sweden
    OK, thanks for the help.
    Just have to buy a couple of new sawzall blades and start cutting then:D
    Buy the way, Nice webpage! I checked out the link in you signature.
  9. readymix
    May 30, 2004
    6,706
    26
    Thanks, I have not had time to update it in a long time. Soon I will be running a new image gallery. Just need to redo all the HTML.
  10. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    I've found that with aluminum that high quality sawzall blades intended for wood work exceptionally well and don't clog up nearly as easily. I would expect that Mag would behave the same way. Smear a little paraffin wax on the blade from time to time and off you go!
  11. readymix
    May 30, 2004
    6,706
    26
    I had no issues at all cutting through 5 sets of the mag's with one Lennox blade. The blade still looks and cuts like new except for the missing paint.
  12. darkshadow
    darkshadow 1 ton status
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    yeah it would be hard, but if you really want some fire works throw some water on it when it is burning!!!
    BOOM!, dry dry dry sand, or a class'D' extinguisher only!
  13. readymix
    May 30, 2004
    6,706
    26
    I set some on fire in the driveway the other day with a MAP torch.
    It was pretty cool...........and bright.
  14. darkshadow
    Dec 6, 2003
    12,250
    C-eh-N-eh-D-eh
    try the splash of water trick for a real show :D
