whats the equation for crawl ratio?
Discussion in 'The Garage' started by 84gmcjimmy, Nov 7, 2004.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    I have 1 saved on the internet, but I want the equation, not the acutal calculator. Most of the calculatos don't use doublers, etc. for them.
    I'm trying to figure out the ratio of:
    th-400, 203/203/205 and 5.13 gear ratio.
    Anyone have the eqation?
    How do I figure it out for atlas or a klune v?
  2. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    2.48x2x2x1.96x5.13 = 99.74 for the trans, tc, tc, tc, and gears you listed.
  3. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    just multiply your lowest transmission gear by the low range in your transfer case(s), then the axle ratio. I have also heard that you get another 2x from torque converter slip in autos.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    yikes, thats still not very good.
    Whats the numbers I would use for an atlas and a klune-v ?
  5. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Just get rid of the TH400 and go SM465...all the crawl ratio you need
  6. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Nah, I already have the th-400, and I want an auto anyways.
    I guess I'll be fine.
  7. jac6695
    jac6695 1/2 ton status
    May 2, 2002
    1,860
    Christiansburg, VA
    ... 99.74 .... yikes, thats still not very good...
    Can you explain why that isn't a good crawl ratio for an auto? /forums/images/graemlins/confused.gif
  8. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    Sure. /forums/images/graemlins/smirk.gif
    Kid, step away from the computer and go 'wheeling, for a change.
    i agree, 99.74 is alot moer than alot of people on this site.
    if you had 2 vehicles with the same crawl ratio and tires, one a stick and one an auto, the auto will go slower. you have to remember the torque converter. there is no way that i know of to find the ratio of the converter, but also remember that it changes with the rpm.
  9. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    crawl ratio doesnt change with a convertor
    convertor slippage is not the same as crawl ratio
    one could slip a clutch and go slower as well
  10. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Depends on which ratio Atlas you use. Now if you put the low 1st gear kit in the TH400 with a Klune and a 5.0 Atlas you'd have this....
    2.75x2.73x5.0x5.13 = 192.57 I think someone makes a 3.00 first gear for the TH400 too. /forums/images/graemlins/thinking.gif
  11. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i know that a converter is not the same as crawl ratio, but it does slip and it does alow you to go slower.
    yes you can do it with a clutch but after a while the cluch will burn up, the torque converter is made to slip.
  12. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Torque multiplication varies with the design of the converter's vanes. 2:1 is a reasonable generic number. So if the gears multiply to 99:1 and you operate the engine below the converter's stall speed you should have at least 198:1 (effective) and possibly more.
    The TH-425 converters originally put in the GMC M/H's have a 2.6:1 multiplication ratio. This was done b/c of the 3.08 final drive, 235R16 tires, and a 12,000 lbs. M/H. Good luck finding one. Most parts books list it as being the same as the other TH425 converters.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    you read "torque multiplication" to equal "gear ratio"?
  14. dremu
    Feb 27, 2000
    15,968
    461
    East of San Francisco
    Sure. Gearing down 2:1 multiplies torque 2:1, right?
    -- A
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I meant is isn't good compared to a stick. I know I am comparing apples and oranges when talking about auto and manual...
    Isn't a stick with a 205, the same ratio as a auto with a doubler? /forums/images/graemlins/frown.gif
  16. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    Ah, so I can buy gears for the th-400 to make it slower too? /forums/images/graemlins/yikes.gif
  17. ntsqd
    Nov 28, 2002
    3,381
    So. CA
    Yes. You think it's different?
  18. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I think what he's getting at is that a slipping torque converter doesn't offer any gear reduction or torque multiplication. It's turning power into heat instead of putting it to the wheels.
  19. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I agree with tim. However, it does affect the final ratio but the *torque* output isn't affected. Gears are not the same as a viscous fluid. The extra power used to make the extra turn is given off in heat and not in power. So, you'll go slower but have the same power is how I see it.
  20. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    [/ QUOTE ] There is something you guys do not get. If there is anything but a 1:1 gearing that affects the final torque. Of course it doesn't increase the initial input torque(the motors power) but by the time the power reaches the wheels the torque IS affected there by there IS torque multiplication. If you guys want to go on arguing there is no such thing as torque multiplication and that its the biggest myth in the automotive world be my guest, give TCI tech line a call and have a dandy argument, I'd like to hear a recording of it. The automatic transmission works on 3 principals, hydraulics, friction, and HEAT. Heat is always wasted energy and the more spinning the more wasted energy but if there is a notable variance in torque at the wheels by even 1% you guys are completely wrong and should stop arguing about it.
