What's the hot ticket for axle gear setup??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NewK5Guy, Sep 21, 2002.
  1. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    What\'s the hot ticket for axle gear setup??
    Running a 6.2 diesel, 700r4 tranny, 208 (241 in future, maybe) t-case, 35" BFG MT's. What's the hot gear ratio to use? Right now fuel mileage is phenominal due toe crummy gearing in the stock axles now, but taller gears are definately needed to help me get up hills and keep up with traffic. Them aforementioned crummy gears don't keep the motor high enough in the revs (if you can say the 6.2 has high revs) to allow quick shifts for passing and climbing hills. I don't know what's in now without pulling a cover. I tried rotating the ds and counting axle turns, but came up with a rediculous 2:1 ratio.
  2. azblazor
    May 5, 2001
    1,953
    Arizona, Phoenix area
    Re: What\'s the hot ticket for axle gear setup??
    You probably have 3.08s. With 35's 4.10s are good.
  3. ntaj*ep
    ntaj*ep 1/2 ton status
    Feb 4, 2002
    3,248
    Evergreen state
    Only lift one wheel and put the trans. in neutral. If you anr not already. /forums/images/icons/grin.gif
  4. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    I've got 4.56 on my 6.2/700R with 35" BFGs (for now). If you do alot of highway driving (fast) stick with 4.10s. If you can stand to cruise @ 65mph and want alot of low speed grunt 4.56 work great, with an OD. /forums/images/icons/wink.gif
  5. carolina custom
    carolina custom 1/2 ton status
    Dec 29, 2001
    161
    Mt. Pleasant SC
    I ran 35s with 4.10 for years with a th400 with no overdrive. This was a great set up. Recently I switched to 4.56 and this was ok with 35s(2900rpm at 65mph). I recently switched to 37s but havent put any highway miles on. I would say if you want mour power or wil ever get bigger rubber(you know you will) get the 4.56s /forums/images/icons/grin.gif . You do have overdrive.
    marc
