what's the lowest I can go?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by possum, Jan 10, 2002.
  1. possum
    possum Registered Member
    Jan 9, 2002
    72
    NC
    what\'s the lowest I can go?
    I have a 12b rear and 10b front. Can I go to 4.56 in these or will I need bigger "cases" or whatever they're called. Pumpkins, whatever. Still learnin the lingo.[​IMG] I may only go 4.10 but I want to know my options.
  2. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    Re: what\'s the lowest I can go?
    4.56 gears will work, the only thing you have to watch is you will have to have a 4 series carrier for the 12 bolt, you can use the 10 bolt carrier as long as the gears you have now are at least a 2.73 ratio or higher. The same goes if you decide to use 4.10 gears.
  3. possum
    Jan 9, 2002
    72
    NC
    so what is the carrier? basic terminology I'm sure but I still don't know. [​IMG]
  4. 1bigk10
    1bigk10 1/2 ton status
    Dec 20, 2001
    151
    Medford Oregon
    The differential (carrier) is in the axle housig its what hold your ring gear and spider gears.Its what transfer power from your driveline to your wheels.
    1982 K10 Silverado. [​IMG] 327 SHPE powerplant SM465/205,15"custom lift 38.5"TSL/SWAMPERS 12boltrearD44 front,3.73 gears.
