Whats the manual transmission in 82 6.2L?
Discussion in 'The Garage' started by JunkYardCrawler, Nov 18, 2004.
  1. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    i have an 82 3/4 ton diesel doner truck. it supost to have a 4 speed with over drive in it. i'm trying to figure out wether or not its the same as my sm465 but with an overdrive for fourth gear. all i have found on the web so far is that the 4 speed with overdrive was diesel only.
  2. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    it is a new process A833 4 speed /forums/images/graemlins/smile.gif
  3. rjfguitar
    Aug 28, 2002
    9,096
    144
    california
    I thought only the th700R4 4 spd OD auto was available behind the 6.2? /forums/images/graemlins/screwy.gif
  4. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    No, you could get the 465, the other mentioned above, a TH400 or the 700R4.
    John
  5. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    The 82 K10 I nearly bought at the boneyard had a 4 speed in it,I thought it was an SM465,but it looked different--it did have "OD" on the shifter! /forums/images/graemlins/doah.gifand I thought it looked just like the Mopar 4 speed they used with the slant 6 in telephone company vans in the 80's!--too bad they crushed it before I got there with the cash /forums/images/graemlins/angryfire.gif(I was PISSED!)--even more now that I know it wasnt just the run of the mill SM465 4 speed.If I had my way that deisels truck chassis and drivetrain would have been under my 74 cab and bed,but its history now--darn scrap happy boneyards! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/rolleyes.gif
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    I think if it is a 465, there is no OD, the 4th gear is 1:1
    Could be wrong, still on first cup of coffee.
  7. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    GM did offer an overdrive 4 speed manual in the early 80's, and not just for the diesel pick-ups. A friend of mine had an 83 or 84 305 powered pick-up with one of those tranny's in it.
    I've heard they weren't the most durable manual out there, and they are fairly rare. No granny either IIRC.
    Rene
  8. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Nope, no granny gear in those. Only seen one in my life, and it eventually blew up behind a swapped in 250ci I-6.
  9. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    I have a 83 6.2 with a manual sm465....... /forums/images/graemlins/thumb.gif
  10. dyeager535
    26,979
    I saw an '82-ish truck in the wrecking yard that had a 4 speed that obviously wasn't the 465. The tranny and t-case shifter "bezel" was all one piece, and th shifter came out WAY further back on the transmission tunnel than the 465, likely because the light duty 4 speed shifted on the side, not the top like the 465. (thus external shift rods that place the shifter near the back of the transmission)
  11. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    it looks alot like my sm465. has a granny top loader. it just drives on the freeway like it has an over drive. granny low then 1st 2nd 3rd 4th. i have both my blazer and this truck stiped down to their frames beside eachother right now. the trannys look really simmilar but have some diffrances.
  12. tRustyK5
    Jul 23, 2000
    36,173
    1,384
    E-town baby!
    So it's a 5 speed?
    My Jimmy when I got it came with the 465/208 stock and had 33's on it. It had 2.73's so I had to use granny to get it moving...and 4th ended up being a lot like overdrive. My cruise rpm was 1800 rpm.
    Rene
  13. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    oopps sorry. just granny through 3rd. at first glance to me it looks like my 465, but looing at it more closly it just looks diffrent. seems to be the same in low gears as my blazer. maybe the 4.10s in the 3/4 tons diffs is enough to make it feel like it has an over drive. cruzes at about 70 on freeway at like 1800-2000, no tach so give or take a few. where my blazer cruzes at 55 at around 2500 on its tach. blazer is running 4.56 gears in te diffs. the 3/4 ton is on bald 33s and my little k5 has 36s. just trying to besure befor i sell the wrong tanny.
