What's the max weight I should tow??
Discussion in 'Tow & Trailer' started by dallassnowman, Mar 14, 2004.
  1. dallassnowman
    dallassnowman 1/2 ton status
    Sep 14, 2003
    339
    Forney, Texas
    What\'s the max weight I should tow??
    Its a 82 6.2L diesel blazer, stock except for 33's.
    My father in law has a camper he thinks is 3k-4k. /forums/images/graemlins/1zhelp.gif
    Just dont want to tear anything up, its my daily driver.
  2. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Re: What\'s the max weight I should tow??
    Your profile simply says "stock". What kind of gears are you running?
    I personally wouldn't tow any more than about 5000 lbs with the K5, and that's providing you have a good trailer brake setup as well as a weight distribution hitch.
    Seeing that you're running 33s, your diesel really needs 3.73s at the very least. My 6.2 half ton has 275/75/15s with 3.42s and when I used to tow my 3500 lb TT through the mountains there were times I cursed the 3.42s........
    If your truck is equipped with a 700r4, a good auxialliary tranny cooler is a must, but I'm sure you've already read that more than once.
  3. dallassnowman
    Sep 14, 2003
    339
    Forney, Texas
    Ok so maybe thats the beginning of my problem....I dont know what I have. How do I find out the gears and tranny??
    Please go easy on me Im a newbie. My first truck was a nissan 4-cyl....!! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/k5.gif
  4. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    Well you might start by looking in your glove box to see if you still have the sticker with the codes or the options.
    That will tell you everything you need to know.
    If you don't have it, then we can walk you through checking things but it will be messy
  5. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    even if SPID label is intact still it probably wont list axle ratio other than it being GQ1 std
    tranny just look under the truck and check the pan shape, cuz the model wont be listed on SPID label, just the RPO code, but if its a 700r4 it will say four speed auto at least, otherwise it will just say turbo hydramatic
