What's the problem here?????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazerGuy, Nov 21, 2000.
  1. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    What\'s the problem here?????
    My 305 runs real rough when I first start it up. Almost sounds like it's not firing all eight cylinders, but it eventually smooths out. I thought it was due to the cold mornings(30 degrees) but I started it this afternoon(65 degrees) and it ran rough. I need to increase the idle 'cause it's at 500 right now. Would that solve the problem? The carb is about 3 weeks old. Also it puffed out black smoke this afternoon, but it wasn't a lot. Thanks for your input.
    [​IMG]FUN WITH 31's![​IMG]
  2. JimmyDie6.2
    JimmyDie6.2 1/2 ton status
    Jun 20, 2000
    453
    Long Island
    Re: What\'s the problem here?????
    this is novice input, but is the choke set right?? I had mine rebuilt and the choke was outtawack (brooklynese). I had a friend "recalibrate it" and it ran smooth, also check your timing anyway, it takes only a couple a mins. and make sure all you plugs are tight and the wires are snug.....goodluck..........JS
  3. JimmyDie6.2
    Jun 20, 2000
    453
    Long Island
    I don't mean to post twice but i forgot to mention. In drive, and stopped, and at operating temp, you should be idling at about 750. pop your hood and check your emissions sticker. you neglected to say what year.......js
  4. Gopherkiller
    Gopherkiller 1/2 ton status
    Aug 14, 2000
    188
    You call 30 degrees a cold morning? where you at, Hawaii? Get your hot idle up where it belongs (900 rpm,) and also check your chock pull off for proper operation.
  5. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    hey gopherkiller here in az 50 is a cold morning lol about the truck sorry cant help there
    [​IMG] SlyDog [​IMG]
  6. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    I got the idle back up to 850 and it runs fine now[​IMG]. Hell, 80 degrees is a cold morning in Texas[​IMG][​IMG] 30 is getting into the artic temperatures.
  7. RAY
    RAY 1/2 ton status Premium Member
    Jul 4, 2000
    281
    Austin, Texas
    Blazerguy, how did you fix this problem, I'm having the same problem with mine.
  8. BlazerGuy
    Apr 20, 2000
    9,206
    abcde
    The idle was too low on my new carb(500 RPM), so I got it up to around 850 and it works fine now. I think I need to adjust my timing though, you might wanna try that on yours.
    [​IMG]FUN WITH 31's![​IMG][​IMG]
  9. EDdaTREE
    EDdaTREE 1/2 ton status
    Feb 18, 2000
    1,253
    Austintown, OHIO
    Hell...30 degrees in Ohio isn't even worth puttin' yer shoes on! We consider -30 "a little chilly".....anything above zero is shorts weather.
