whats the problem?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by therover87, Jun 24, 2001.
  1. therover87
    therover87 1/2 ton status
    Jun 24, 2001
    139
    Long Island, New York
    i have an 87 k5 and i replaced the wires with msd 8.5mm, i have the msd hei coil, the cap and rotor, i have ac delco rapidfire spark plugs but for some reason my truck is running very rough at idle and it seems like there is a lack of power, there is a backfire through my exhaust as well any help would be appreciated
  2. KrebsATM02
    KrebsATM02 1/2 ton status
    Mar 21, 2000
    553
    College Station, Texas
    have you timed your engine lately?
    Doug Krebs
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Sounds like a wire got cross over with another one.
    Also, were the coil wires the same color when you took the old one out and put in the new one? If I remember right, there is a yellow, red, and white wire but certain years only use two of the colors and other years use the other color.
    <font color=red>I m so we Todd did.
    I m sofa king we Todd did.</font color=red>
  4. txbartman
    txbartman 1/2 ton status
    Jun 1, 2001
    1,975
    Plano, TX
    I agree with the timing issue. When you accelerate, does it seem to significantly hesitate before it responds? If so, combined with your other problems, I would say you are firing late.
    85 GMC Jimmy, 305 w/TH700-NP208, 32X11.5 BFG ATs, 15x10 Eagles, Smittybuilt tube nerf bars and bumbers
  5. tRustyK5
    Jul 23, 2000
    36,170
    1,375
    E-town baby!
    I'm with Westy on this one, I think you got a couple of wires crossed.
    Rene
  6. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    I concur - check the wires
    I'm so poor I can't even pay attention [​IMG]
    <A target="_blank" HREF=http://pugsley.alloffroad.com>http://pugsley.alloffroad.com</A>
  7. shawnboy
    shawnboy 1/2 ton status
    Jun 22, 2001
    468
    Toronto, Canada, eh.
    Like the other fellas said, check to see if your wires were r&r'd properly. But just as important is your spark plug gap. Stock .035 works ok for stock ignitions but when you run that MSD you have to set your gap at least to .045-.050 to run cooler. Very important.
    Shawnboy.
  8. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    Have you looked for vacum leaks yet? That and timing ,wires Are things i'd look at.
    Have Fun Cethern
    Lost? i'm not lost i'm just disorienated
  9. therover87
    Jun 24, 2001
    139
    i am not sure cause this problem just started and i have had the wires on for about 3 months
  10. therover87
    Jun 24, 2001
    139
  11. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    One other thing to check is the length of your spark plugs (threaded portion). Older Chevys used the shorter reach (.460) and newer chevys (86 on I believe) used the longer reach (.750). This is important to get the plug tip into the combustion chamber. If they are too short, they will not fire the cylinder properly and foul out real quick (they won't get hot enough to burn off the fouling). Just a thought.
  12. slider79blazer
    slider79blazer 1/2 ton status
    Mar 23, 2001
    164
    littleton,co.
    you say it just started and had the wires on for three months you might have a wire that rubbed or is shorting out on something. also "rough at idle" is that in drive or park. if it is in drive I would look for a vacuum leak. hope this helps. good luck
    whats a 4 letter word for farm wagon? (ford) [​IMG]
