Whats the proper way to do paint touch ups?
Discussion in 'The Body Shop' started by afroman006, Jul 11, 2004.
  1. afroman006
    afroman006 1/2 ton status
    Aug 21, 2002
    2,876
    My burb has some paint flaking off in spots and a few are starting to rust /forums/images/graemlins/angryfire.gif /forums/images/graemlins/yikes.gif /forums/images/graemlins/doah.gif /forums/images/graemlins/shame.gif. I have a little bottle of paint that I got at the dealership but I just put it on a couple places (without any prep) and it flaked off prety quickly. Whats the correct way to cover up bare spots like that and how do I remove small specs of rust before I paint? Thx
  2. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I'm assuming it's not clear coat. Is it a rattle can or were you brushing it on? A wire brush, some good medium-grit sandpaper and denatured alcohol should do the trick for prep, then put several thin coats on to ensure a good base. The alcohol will get all the remaining grease and moisture off the metal so it has a solid base to stick to, and the wire brush will make the surface rough for good adhesion. /forums/images/graemlins/waytogo.gif
  3. afroman006
    Aug 21, 2002
    2,876
    Its the little brusk on tube they sell at the dealerships. So basically, rough up, clean, then paint. Cool. Would it be ok if I thinned the touch up paint? Its kinda thick and last time i put it on it went on globby. Thx
  4. 75-K5
    Apr 28, 2002
    5,353
    Anderson, Indiana
    You could probably thin it a little bit if it's globby. Go easy on the thinner though.
