What's the tranny in 80's 1 ton crewcab
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 88k5canuck, Apr 9, 2002.
  1. 88k5canuck
    88k5canuck Registered Member
    Mar 1, 2001
    26
    Ontario, Canada
    What\'s the tranny in 80\'s 1 ton crewcab
    I was out looking at an early 80's Chevy 1 ton crewcab. It has a d60, 14bolt, 350, 205 and a 4 speed standard. My buddy is looking chopping the rear frame and moving the rear axle closer to the front. Does anybody know what tranny that is and the gear ratios.
    Thanks for your help
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Re: What\'s the tranny in 80\'s 1 ton crewcab
    Its an SM 465.
    Ratios
    1st - 6.55
    2nd - 3.58
    3rd - 1.57
    4th - 1.00
  3. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    3rd is 1.70:1
    Rene
  4. dyeager535
    26,979
    I didn't follow the "I counted the SM465 gear ratios thread" : ) but I noticed as I was about to update my transmission gear ratio chart with that info, that the SM420 has gear ratios that are almost identical, with a very similar looking case.
    When that 1.70/sm465 info was obtained, was the tranny positively ID'd, and/or will the gears that make up the 3rd gear set interchange between the 420 and 465?
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    I knew I'd get that one wrong. I was going to put 1.70 but used the other #.
    Oh well. Thanks Rene. /forums/images/icons/smile.gif
    John
  6. tRustyK5
    Jul 23, 2000
    36,170
    1,377
    E-town baby!
    I saw the tranny on MJ's bench. It was a 465.
    Without having one to check my only guess is that the SM420 has the 1.58:1 3rd and 'assumptions' are made when tech articles are written.
    I've also seen slightly diferent ratio's listed for the NV4500. Some sites list 5th as .70:1, others say some years are .73:1 and other years are .75:1. I'll count the teeth on mine.../forums/images/icons/smile.gif
    Rene
  7. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    I wish it was a 420, i would sell it to a jeep nut for $$$
    pretty hard to miss the huge wart on the side of a 420 case
