What's the weirdest not-made-for-a-truck part on your truck??
Discussion in 'The Garage' started by heavy4x4, Oct 23, 2002.
  1. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    What\'s the weirdest not-made-for-a-truck part on your truck??
    For me, I'd have to say it's my aux tranny cooler mount. I cut, painted, and mounted a piece of shelf bracket (yup, that metal bar with slits in it for the little shelf clips) which my tranny cooler is zip tied too. I think it's a better option than putting the zip ties through the radiator, and it works pretty dang well.
    So, what about everybody else, what's the weirdest part on your truck, not made for a truck?
  2. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    Re: What\'s the weirdest not-made-for-a-truck part on your truck??
    well i got a yosimitie sam zip tied to my grillie. i have a interior light that is the rear tail light for a yamaha 4 wheeler, had an 1157 bulb in it, i got it wired to my floor light, so now i have a super bring interior light, so i can acctually see stuff in my cab, i have a blanket covering my seat, has wolves howing at the moon on it. i have i have a piece of garden hose as my rear diff vent tube, and it works. go figure, i also have orange extension cord wire running to my daylighters on my roll bar and it is double insulated so it works great, and its plenty thick, plus i have one more wire that i can run power up there too. yeap it is funny what you can do if you use alittle bit of the knowlage you have, and a few tools. /forums/images/graemlins/cool.gif
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  3. heavy4x4
    Aug 28, 2002
    3,270
    Ok, ok. You win dude. /forums/images/graemlins/thumb.gif
    With all those non-truck parts, does it even resemble a vehicle anymore? /forums/images/graemlins/cool.gif
    Good ideas, that's one of the reasons I asked this, to get/throw out some ideas to others.
  4. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    I would have to say the log splitting blocks being used as shims on the rear axle. Got them from Agri-Supply for 3 bucks a piece. Came home and drilled holes in them to bolt to my center pins. Work great, don't break, and won't rust.
  5. 87sm465np208
    Aug 28, 2002
    1,114
    illinois
    yea it does, i just used what i had to make what i needed, and it works, so im pretty proud of myself, yea, the only thing that i mentioned on my post that is differnt is the yosimitie sam, but i think the tail light idea is a keeper, because it lights up two filiments in the bulb, and it lights up the whole cab really well, i found the tail light in a mud hole, took the red filter off, drilled some holes in the plastic, drilled some holes in the 1st layer off roof, not the second outer layer /forums/images/graemlins/wink.gif, and then installed it with two sheet metal screws, wired it to my floor light, wow, boy howdy i tell you what, that was a good idea. /forums/images/graemlins/thumb.gif
  6. BigBluOx
    BigBluOx 1/2 ton status
    Aug 30, 2001
    301
    Auburn, WA, USA
    How about the small canvas sack with two tennis balls in it hanging under my rear bumper just behind the fuel tank? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Jon /forums/images/graemlins/burb.gif
  7. GMslave
    GMslave 1/2 ton status
    Oct 3, 2002
    113
    Flint, Michigan
    It'd be a toss up between the hand grenade drilled and tapped for my t-case lever (the irony kills me), or the handicapped bathroom grab bar bolted to the dash board. /forums/images/graemlins/eek.gif
  8. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    "SpongeBob" air freshener.
    John
  9. BigBluOx
    Aug 30, 2001
    301
    Auburn, WA, USA
    I like the way you think /forums/images/graemlins/grin.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  10. Ryan Melton
    Ryan Melton Registered Member
    Dec 15, 2000
    61
    Texas
    I have a bilge pump for a boat in the cab to pump out water during deep crossings. Definately not a factory option.
    Ryan
  11. Quack_Addict
    Quack_Addict 1/2 ton status
    Feb 24, 2002
    119
    Michigan
    Bilge pump... hahaha!
    Well, when I installed a new, larger radiator (4-core to replace the 2-core), the radiator was taller too. I had to modify the radiator schroud... with a couple pieces of 2x4... to take up the extra space. Works very well.
    /forums/images/graemlins/truck.gif &lt;--- Looks like my `84!
  12. bablazer73
    bablazer73 1/2 ton status
    Apr 4, 2000
    3,363
    upstate ny
    The chain wrapped around the frame to tie my big stupid dog to!! the only thing he CAN'T move in my yard!! does that count??
  13. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    my leapord print headliner and t-case boot.
    Also, the skull shifter knob named Bob. as in Bob the Knob /forums/images/graemlins/rotfl.gif
  14. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
    That would be my tranny cooler itself. It's an AC coil that I took out of an old window unit. It's plenty big, looks good and was made just right to mount it good. Of course then there's the piece of plumbers tape and sheetmetal screws holding my fan shroud together, and the 1x4s in the battery tray and thermostat wire for hold downs. I also have sheetmetal straps and pieces of chain for my exhaust supports. /forums/images/graemlins/pimp1.gif
    You can usually tell what the previous owner did for a living by the type of rigging they used.
    Oh yea, I almost forgot the JB weld that's sealing whats left of my t-case after it threw the chain. /forums/images/graemlins/ignore.gif
  15. trouble1
    trouble1 1/2 ton status
    Sep 28, 2002
    346
    travelling, probably lost
    A Old lawn chair for a drivers seat...A old towing strap to mount it...and duct tape to hold the windows in place...All this is obviously temporary...and I'm not sure if the duct tape counts cause Ive never seen a off road rig not have it and bubblegum holding something together... /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/k5.gif
  16. heavy4x4
    Aug 28, 2002
    3,270
    trouble1,
    I don't know if you have a digital camera or not, but, take whatever means necessary to post a pic of your lawn chair drivers seat. I've got to see that.
  17. trouble1
    Sep 28, 2002
    346
    I got a little cheap disposable camera ...as soon as I use it up I'll get walmrt to develop it on a CD for me, then go to the library to find a way to post it....It should make for some of you to get some great laughs. Most of this is not really funny to me, but every once in a while I look at it and you just cant help to laugh /forums/images/graemlins/tongue.gif /forums/images/graemlins/k5.gif
  18. thatK30guy
    Jan 12, 2001
    32,076
    55
    The weirdest not-made-for-a-truck part on my truck would the the loose nut behind the wheel!! /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  19. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    HAHA now that is funny..lets see for me...hmmm maybe the orange fuzzy dice hangin from the rear veiw...i also have grey interior! /forums/images/graemlins/blush.gif
  20. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    A set of Dodge Stratus hood-struts, being used as bump-stops in the rear.
    Basicly, super-high powered gas-shocks. High compression resistance, very-little rebound.
    (well-soon to be anyway, still goofing around with 'em, right now)
