What's the whole purpose of lifting?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by flash_point, Nov 22, 2001.
  1. flash_point
    flash_point Registered Member
    Apr 5, 2001
    27
    CA
    What\'s the whole purpose of lifting?
    I know that many people do it solely for looks.But is it just to clear the body of the vehicle to install meatier tires on there or is there another purpose?
  2. AJMBLAZER
    AJMBLAZER Better to be lucky than good. Premium Member
    May 18, 2000
    22,793
    100
    Paducah, KY
    Re: What\'s the whole purpose of lifting?
    The purpose of a lift is to fit bigger tires, so you gain more ground clearance off road.
    A body lift accomplishes this by just moving the body farther above the frame, and giving you more room for bigger tires.
    A suspension lift accomplishes this by making the spring packs (leaf springs on GM solid axle trucks) taller giving you the clearance between the frame, body and tires. Added benefit of suspensions lifts is that if you choose wisely, you can improve ride and suspension flexability with a good set of spring packs.[​IMG]
    1992 Blazer Sport, 350, TH700, 2" Rancho[​IMG], 285/75R16 AT's, Flowmaster, K&N, MSD stuff [​IMG]
  3. CaptCrunch
    CaptCrunch 1/2 ton status
    Feb 2, 2001
    3,596
    Minnesota
    I dunno about you guys but I personally lifted my vehicle so I could look down on the good look'n girls in tight, low cut tops [​IMG] LMAO [​IMG] [​IMG]
    -Mikey
    1987 Chevy K5 Blazer- 350 TBI
    <a target="_blank" href=http://coloradok5.com/gallery/captcrunch>http://coloradok5.com/gallery/captcrunch</a>
  4. thatK30guy
    Jan 12, 2001
    32,076
    55
    Lifting is so you can crush the cop cars!!! [​IMG] [​IMG] [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
  5. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    I didn't go for the big lift in my case because there's no point. Here in Iowa I dont need to worry too much about ground clearance. That and I'm a wussy that wouldnt take it off-road for fear of damaging all my body work. I had a broken leaf spring and just put in ones that were rated for 3/4 ton duty. Gave me about an 1" lift and took out alot of the sway on hard corners. Another little perk of having a lift is that it is easier to crawl under and do work on it. Its a b!tch though to climp up to work under the hood.
    <a target="_blank" href=http://new.wavlist.com/movies/031/ag-blow.wav>"I ain't nobody, dork."</a>
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  6. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    HAAAA but then there are us "good looking girls with tight/low cut tops on" with our own lifted trucks, all your gonna when you pull up next to me is my shoulder
    LOL
    --Brandy
    IF ONLY THE 4 YEAR OLD COULD TURN A WRENCH
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear 12 bolt dana 44 front, TIRED ol 305-
  7. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    I lifted mine to keep the bottom of the Jimmy off the rocks. I wont go any higher than 4" because that is the most stable. I can still tow with the 4" lift on my burb. The burb is more for looks but still goes out wheeling every once in a while. I will be stepping to 38.5s on the Jimmy but will cut the fenders to fit. I need more clearance but dont want the negative affects of the higher lift with suspension
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  8. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    I like that one [​IMG]
    <a target="_blank" href=http://www.whiteknight.scriptmania.com/>http://www.whiteknight.scriptma
    nia.com
    </a>
  9. Pugsley
    Pugsley 1/2 ton status
    Jan 16, 2001
    3,556
    Tucson, Arizona
    Why do you guys/gals think that I like riding around in those big red fire engines??? The back/rear facing seats provide the ultimate vantage point for those tight/low cut tops[​IMG]
    ......And knowing is half the battle
    <a target="_blank" href=http://pugsley.alloffroad.com>pugsley.alloffroad.com</a>
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I try to stay away from those kinds of girls. [​IMG]
    Tim
  11. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    LOL... I was wondering who would be first to pick on my little joke LOL. [​IMG] It is actually pretty surprising to see one in a lifted truck around here. That would be cool though [​IMG]. If they are higher then me then I guess they can look down on me [​IMG]
    -Mikey
  12. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    I think most of us pulled next to Theresa in White Knight would just see Rocker panel LOL [​IMG]
    -Mikey
  13. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    speaking of back rear facing seats, i did this to make more cargo room. and it works very well. then i found a better way. TAKE IT OUT.
    sorry to change the subject
    1974 Chevy Blazer Cheyanne. but it is on 33's now, with saggy old springs. i am in Yuma Arizona if ya got any parts for me.
  14. flash_point
    Apr 5, 2001
    27
    CA
    You guy's crack me up:D So would you guys suggest a 4inch lift just for clearance room (a just in case type thing) w/ some 35" tires?
  15. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    A 4in lift with 35's. You will have to do some fender trimmin. If you do any serious offroading.. 4in lift with 33's and your Ok most of the time..I have a 4in lift and 33's and I have scrapped my fenders....Dan
    If it ain't broke.......Don't fix it....
    <a target="_blank" href=http://coloradok5.com/gallery/Gokartergo>KLICK</a>
  16. CaptCrunch
    Feb 2, 2001
    3,596
    Minnesota
    33's and a 4" loft for flex. 4" and 35's would probably be nice with a little trimming if you want to flex alot.
    -Mikey
  17. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> 4" and 2" body with 35's or just 6" and 35's ................perfect set up !
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
    <font color=purple> BOW CHICKA BOW WOW !
  18. big75jimmy
    big75jimmy Registered Member
    Jun 26, 2001
    77
    Kirksville MO
    I had a 4" lift and 33"s, but it just wasn't big enough. So now it has 8" suspension and will soon have a 3" body lift and 44"s
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Be prepared to cut your fenders.
    My buddy has 12" suspension, 3" body, and 44x18x15 Ground Hawgs. His fenders aren't cut, and he has rubbed before.
    Tim
  20. Russell Keys
    Russell Keys 1/2 ton status
    Mar 16, 2000
    253
    Huntsville, TX
    I'd say a good round # like 20" and 44's.
