Whats this do??
Discussion in 'The Garage' started by js4x4, Dec 17, 2004.
  1. js4x4
    js4x4 1/2 ton status
    Jul 17, 2004
    798
    San Diego, CA
    Ok, I have an 87 engine (TBI) and i know you disconnect the tan/black stripe wire to set the base timing....aside from disabling the electronic advance, what does it do?? or disable, is more accurate maybe? does it remove the computer altogether from all systems?? I'm just trying to rule something out. It runs great unplugged (well, 'cept it doesn't advance the spark), but connected at idle, in gear it stalls.
    Any thoughts fellas?
  2. js4x4
    Jul 17, 2004
    798
    San Diego, CA
    nobody??
  3. 90v1500
    90v1500 Registered Member
    Oct 1, 2004
    56
    Huntsville, AL
    Are you getting any "codes"? There are a few things it could be, Knock sensor, Distributor (weak magnets), , EGR, or ESC. If you do a search there are a few posts about this problem. On mine it was the knock sensor.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    It makes it so you can set the base timing.
  5. js4x4
    Jul 17, 2004
    798
    San Diego, CA
    yeah, i know it sets base timing, was just curious what else it disabled....i've replaced all the sensors already. Should the EGR be movable by hand??
  6. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    Flux Capacitor maybe? Seriuosly I think it just disables the electronic advance.
  7. js4x4
    Jul 17, 2004
    798
    San Diego, CA
    I actually bypassed the flux capacitor with a paper clip and a wad of used gum...thats not 'bad' is it??.
    Seriously, Thanks, thats what i thought....i've been thinking it was the TCC solenoid, but man....it doesn't stall with that wire disconnected (and doesn't stall *all the time*, so have been thinking its something else. (i almost replaced the TCC last weekend, but ALL the chevy dealers in SD are sold out of them...) and its really bugging me. I think I'll replace the EGR.....(on a plus side, i have 6 qts of tranny fluid and a filter/gasket set to return) :xmas:
