what's this gauge?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Chris, Mar 3, 2005.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    so..... we got amps, oil, and temp in the regular positions.... but whats that on the bottom left?
  2. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    hmmm, guessing here maybe air pressure ?
    is this out of a c50 series truck?
    i blew up the pic, but cant tell, sorry
  3. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    i dont know what its from. i blew it up too, and couldnt tell. alot of clusters have a clock there..... but it aint no clock..... and its not fuel...
    edit: ohhhhhh....... volts..... 0 - 3.0 - 6.0 - 9.0 - 12.0 - 15.0?
    this is an interesting cluster...... its got the fuel underneath the tach.
  4. blazinzuk
    blazinzuk Buzzbox voodoo Premium Member GMOTM Winner
    Dec 20, 2002
    17,412
    3,799
    Afton / Star Valley Wyoming
    Its air pressure it is probably a daul gauge with one needle that is white and one that is orange.
  5. mr_beer
    mr_beer 1/2 ton status
    Sep 10, 2004
    325
    Mt. hermon LA
    I'd say it is air pressure because I have seen C-70 trucks with the same gauge cluster in them
  6. Stoopalini
    Stoopalini 1/2 ton status
    Oct 17, 2000
    999
    Austin, Texas
    I like that 'fuel' under the 'tach' setup. Anyone know what year/models had a cluster like that?
    Thomas.
  7. dyeager535
    26,977
    That's definitely out of one of the "big" trucks, I believe the one I grabbed a setup out of like that was early 80's.
  8. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    If you want one of those I know where some are
  9. alf4444
    alf4444 1/2 ton status
    Nov 1, 2002
    2,051
    T-ville, ut.
    WHERE?
  10. smalltruckbigcid
    smalltruckbigcid 1/2 ton status
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    77 and newer C-65's and C-70's had that gauge cluster. And that air pressure gauge is for a truck with an air shift 2 speed rear axle and hydraulic brakes. If you didn't ask chev about the how the axle shifted you got the air shift and air compressor for free...but spec air brakes and you got the **** charged outa you and they told you how difficult it was to put an air compressor on that truck, guess how I found out:mad:
    George
  11. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    think that gauge would work with an on board air setup?
  12. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Dont see why not.. wonder if its mechanical or electrical?
    If elec, all you should need is the correct sending unit. If mech, a line needs to be run to the gauge.
    John
  13. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    Will that gague cluster fit in Blazers and Burbs (mine is a '90 burb) or is it too big?
  14. blazinzuk
    Dec 20, 2002
    17,412
    3,799
    The air gauges are mechanical they have two fitting that come out the back I made a jumper hose to make sure they would work for a buddy and they work awesome. There are 2 needles on that gauge and 2 air fittings on the back. I would like to see someone use them I will in my 73 blazer eventually but where I can get them wants 100 bucks and I need to put that 100 bucks elsewhere right now.
  15. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    That gage cluster looks cool.
  16. smalltruckbigcid
    Dec 25, 2004
    3,866
    3
    NE Wyoming
    If the seller wants $100 for just the air gauge you can get a gauge from a semi that will work, standard 2 and an 1/8 inch gauge for a lot less....
    George
  17. justwhatido
    justwhatido 1/2 ton status
    Apr 8, 2004
    1,037
    Mobile, AL
    Will such a guage cluster bolt in place of the stock cluster in a 1973?
  18. mechted
    Oct 19, 2003
    765
    Granbury, TX
    it should... but you need to check a couple guages:
    OIL: mech (73-77/78) or electric (post 77/78)
    VOLT: voltometer or ampmeter... i dont think its a "plug and play" thing, but im not sure
