Whats this piece? Pulled this out of my diff
Discussion in 'The Garage' started by jjlaughner, May 14, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I know what the penny is /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/deal.gif
    Whats the other thing!? /forums/images/graemlins/confused.gif
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    shim maybe? what diff?
    edit: too small the be a shim /forums/images/graemlins/doah.gif
  3. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    That thing is F*CKED-UP! That's what it is. /forums/images/graemlins/rotfl.gif
  4. smprider112
    smprider112 1/2 ton status
    May 1, 2004
    624
    Beaverton,Oregon
    is that a clutch? from a limited slip unit??
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/thinking.gif
    You got me wondering if it had a gov bomb that popped and they tossed in an open /forums/images/graemlins/thinking.gif
    Unknown diff till we have a positive ID on the piece /forums/images/graemlins/thumb.gif /forums/images/graemlins/rotfl.gif
  6. y5mgisi
    y5mgisi 1 ton status
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    It is a shim that goes between the careir and one of the spider gears on the cross shaft...Id put 20 bucks on it.
  7. hd-10
    hd-10 1/2 ton status
    Jan 31, 2004
    188
    lemoore, ca
    thats what it is i guarantee seen it many of times. /forums/images/graemlins/thumb.gif
  8. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    I know what it is!! It's MY penny!!! /forums/images/graemlins/angryfire.gif /forums/images/graemlins/angryfire.gif
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/rotfl.gif
    (it really is my penny)
  9. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Go to page two of my truck web shots and there is a view of a front diff. , it is part # 35
    You will have to play with the view to make it large enough to see clearly.
    Hope it helps you out /forums/images/graemlins/thumb.gif
    BTW nice penny lol.
  10. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    That is the washer/shim from behind one of the spiders gear in a 14bff. In this picture, near the top, is another example..
    I've seen a bazillion of those things when after welding ALOT of 14b's. I have never seen a 14b where atleast one of those things wasn't fawked up in some way. If you happen to need another one, I could probably dig one up for ya. /forums/images/graemlins/pimp1.gif
  11. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/woot.gif Well I'm glad to hear its not a bad (well at least uncommon) thing.... We pulled the cover off the 14bolt and I notided it had alot of sledge in the bottom. I took my finger and wiped the sledge out and got one half of that washer... /forums/images/graemlins/crazy.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/doah.gif we looked and looked to see where it would come out of. Then we got thinking maybe since this axle has the spacer and 4.56's on a 4.10 carrier maybe it had a gov loc and popped and they put in the open without cleaning the inside out real good /forums/images/graemlins/confused.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/dunno.gif
    So where would this piece exit the carrier at?
    [​IMG] /forums/images/graemlins/waytogo.gif
    This is my $10.50 eBay win /forums/images/graemlins/deal.gif
    It's the narrow dually axle, so I'm still trying to figure out if I'm going to use it or not, I just couldn't let this pass on ebay. There was an opening bid of 10$, then about a day and half till the end I made a $12 bid and it ended at $10.50 (the second bid /forums/images/graemlins/yikes.gif)
    So what do you think? Weld on some disk brake brackets out on the spindle and swap to SRW hubs? I was hoping it was the wider of the two dually axles then I would have just put it in the truck with dually hubs for now and had the rear 72" and the front 69-70" (10bolt). But this dually is the 63" WMS axle (the cab and chassie version I think).
  12. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    /forums/images/graemlins/tongue.gif /forums/images/graemlins/whistling.gif
  13. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    Carrier shim was my first guess but it was too small, then the spider shim/washer was my second guess, but I wasn't sure /forums/images/graemlins/waytogo.gif
    I didn't see a place large enough for it to come out of the carrier /forums/images/graemlins/dunno.gif
  14. SF87K5
    SF87K5 1/2 ton status
    Oct 27, 2002
    1,105
    Stedman, North Carolina
    Is correct.
    Hey thats $20 he gets. /forums/images/graemlins/histerical.gif
  15. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    My guess would be through one of the windows in the carrier where you can see the side gears. I'd have to look at a carrier, but IIRC, half of one of those things should fit through there.
  16. Goober
    Goober 1/2 ton status
    Apr 26, 2002
    2,222
    Mayberry (Auburn, WA)
    I found the same thing in my 14 bolt:
    Good thing it's an easy fix! /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  17. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    That looks almost exactly like the piece I found in my 14BFF upon teardown. /forums/images/graemlins/histerical.gif
    I bought replacements from the stealership. I think I paid around $15-20 for a pack of six, which is convenient since you only need 4 in the entire diff. /forums/images/graemlins/rolleyes.gif /forums/images/graemlins/histerical.gif
  18. y5mgisi
    Aug 11, 2002
    17,156
    247
    Portland Oregon
    /forums/images/graemlins/waytogo.gifoh yeah you know i accept pay pal! /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/thinking.gif /forums/images/graemlins/deal.gif
