what's this sending unit for....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Ben Malinski, Oct 22, 2003.
  1. Ben Malinski
    Ben Malinski Guest
    what\'s this sending unit for....
    On the intake between the carb and the distributor on a SBC? 84 full size. What's it for? Thanks! No vacuum lines. These are wires going into the harness.
  2. big pappa b
    big pappa b 3/4 ton status
    Jan 3, 2003
    6,328
    Falcon, Colorado
    Re: what\'s this sending unit for....
    Most likely a vacuum port. Seen it used for the vacuum for the power brakes
  3. Ben Malinski
    Ben Malinski Guest
    No vacuum lines. These are wires.
  4. KRAZIE87K5
    KRAZIE87K5 1/2 ton status
    Feb 23, 2001
    3,369
    Chicago, IL
    Got me! PICS?
  5. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    Sounds like an oil pressure sender to me- is it cylinder shaped? About 2-3 inches tall? Wire(s) plug into the top of the unit?
  6. Ben Malinski
    Ben Malinski Guest
    Your discription is acturate. I have a oil light on the dash in the speedometer housing. Two lights; one brake and one for oil. The light goes out when the engine starts up after a few seconds. So it's working fine I guess. The I have a oil pressure guage. So I take it that the one you discribe is the oil light sending unit?
  7. Can Can
    15,552
    136
    I know for a fact that it is hooked into your oil pressure gauge. It may very well be connected to the idiot light as well. FWIW, if you feel that you need to replace it, it's a super basic swap. The sender is threaded into the intake- unscrew the old one and screw the new one in.
  8. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    All the Chebbies I've ever seen had the oil pressure port in the block, just behind the edge of the intake, behind the distributor. He's describing this piece as being between the carb and the distributor. The only things I can think of to "measure" there are vacuum, EGR temp, or coolant temp. Oil doesn't flow into the intake.
  9. Can Can
    15,552
    136
    Hmmmmmmm.....I've replaced my oil pressure sending unit a couple of times, but I just assumed it screwed into the intake. I never really looked that closely seeing as I was already in a pretty uncomfortable position to begin with. /forums/images/graemlins/wink.gif
    Regardless, the only "piece" back there that is wired up, other than the dist. itself, is the oil pressure sending unit. I beleive on an 84 there may be a ESC hookup too.
  10. HarryH3
    May 31, 2000
    10,384
    Georgetown, TX
    That sumb!tch is definitely in an awkward place! /forums/images/graemlins/eek.gif There's a notch in the back of the intake to clear the hole in the rear edge of the block. /forums/images/graemlins/cool.gif
