What's This?
Discussion in 'OffRoad Design' started by nvrenuf, Jul 22, 2004.
  1. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    What\'s This?
    Ok, I got my Doubler shifter (twin stick) and I have a mystery part. What is the flat piece with the 2 pieces of tubing welded on it? /forums/images/graemlins/dunno.gif
    And as usual, this stuff is SAWEEET! /forums/images/graemlins/thumb.gif
  2. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Re: What\'s This?
    That should be the spacer to locate your shifters in the factory hole in the floor. What tranny are you running?
  3. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Re: What\'s This?
    I'd say a 205 with the twin stick set-up, or at least it will have it sooner or later.
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Re: What\'s This?
    There is a spacer that is needed depending on what transmission is being used, IE: TH350, TH400, 700R4, SM465. All of the transmissions have a different length to them so the shifter has to be spaced accordingly and that is what the spacer is for, some spacers are longer than others.
  5. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Re: What\'s This?
    Ok I got it now, I didn't even think about needing to reposition the shifters. Thanks! /forums/images/graemlins/thumb.gif
  6. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: What\'s This?
    Yup, the spacer makes up for the trans length.
  7. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Re: What\'s This?
    Dr. Watson, did you get my email about the 203 shaft? (Edit: the one with the tracking number)
    Thanks!
  8. Stephen
    Sep 15, 2000
    4,227
    142
    Carbondale Colorado
    Re: What\'s This?
    Yup, no problem.
