Whats this?
Discussion in 'The Garage' started by 84gmcjimmy, Feb 28, 2005.
  1. 84gmcjimmy
    84gmcjimmy 1 ton status
    Dec 3, 2003
    12,838
    B.C. CANADA
    Tried to take the engine wiring harness off yesterday, just need to get the 3 starter wires, a couple other ones, and this guy...
    number 2= the wire.
    number 1= what is that? it looks like I could unscrew it. Cant seem to pull the wire off.
    Thanks.
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    It is the oil pressure sender guage and wire.
    Harley
  3. AkMudr
    AkMudr 1/2 ton status
    Dec 30, 2004
    917
    Alaska
    Oil pressure sending unit switch that goes to yer oil pressure gauge. All is it is a lil knife connector. It pulls right off.
  4. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    alright thanks!
    I'll go back at 'er tomorrow night.
  5. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    how do I pull it off? Tried again and nothing :confused:
  6. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    pull and pulll again.....
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    the rubber boot may be holding it on good, pull the rubber boot off with a screwdriver then the wire should slide right off
  8. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    so I won't hurt it if I pry the rubber with the screwdriver?
    Thanks.
  9. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    take a small flathead and stick it in between the connector and the rubber on both sides to break it free then pull on it... don't pry it tho.
  10. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I went out and did it after my reply. I took a flat head screwdriver and stuck it underneath the boot and it popped off. Ripper a tiny bit though.
    One question... is the white thing suposed to come with it? There is the boot with a slot in it(female side), then the white thing has the male side. does the white guy stay, or how do I get that out? Tried pulling on it but it won't move. All it does is spin.
  11. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    not sure what you mean? do you still have a camera on you?
  12. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    I'll go take a pic, give me 4 minutes:)
  13. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    no you get 3 min and 30 secs:grin:
  14. big83chevy4x4
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    yes the white thing stays, its part of the sensor. if it spins, you may need a new one, never had one do that before
  15. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    pcs;
    so the white thing shouldn't spin?
    to get a new one, do I have to replace the whole oil pressure sender, and the guage?
  16. dirtwarrior17
    May 14, 2004
    1,820
    Redding, CA
    I agree with big83.... it shouldn't spin... Its not worth it to try to jimmy rig something that cheap that will have a huge part in telling whats going on with your motor.
    I beleive a new sending unit is around 20 bucks at autozone but i may be off... been a couple years since i bought one.
  17. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay I will just replace it, if I keep the engine. It still belongs to the PO...but he owes us 300 bucks, so I might just buy it off my mom (he owes my mom the money)
    anyways, thanks guys!!
    one more q, are they all the same, or is there one specific for the engine size/ and year?
  18. 79Stomper
    79Stomper 1/2 ton status Premium Member GMOTM Winner
    Mar 4, 2004
    4,225
    19
    Forest, VA
    There are different types for different years. Just make sure you get the right one for a gauge or dummy light when you do get one. They are around 14 bucks. Just bought one last weekend.
  19. 84gmcjimmy
    Dec 3, 2003
    12,838
    B.C. CANADA
    okay cool. Thanks !
  20. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    yeh be careful, several different ones each year, wrong one and oil wont guage right in dash, get sender for exact year make model of vehicle or put in a mechanical guage setup and do away with factory electric one, now is the time to do so if you wish
    good luck
