Whats this?
Discussion in 'The Garage' started by Avery4jc, Nov 14, 2006.
  1. Avery4jc
    Avery4jc 1 ton status Premium Member GMOTM Winner
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    http://www.napaonline.com/masterpages/NOLMaster.aspx?PageId=430&CatId=3&SubCatId=5
    I've heard some guys talk about these before...so they are in the brake assembly but what do they do?
    I just ordered the S44 to 1350 U-Joint from NAPA online since my local NAPA shop said that it doesn't exist anymore but they had a replacement so I bought it and well guess what it didn't fit so I just ordered it off of their site since I only have a couple more days to get stuff here for the swap...
    Anyway I saw those on there and wondered what they did and how...Thanks!
    -A
  2. NoReGrEtS
    NoReGrEtS 1/2 ton status
    Nov 7, 2005
    848
    Moreno Valley,SO CAL
    the link just takes you to napa and not to a part
  3. 1977k5
    1977k5 3/4 ton status Vendor
    May 26, 2003
    9,995
    133
    Yep, it requires you to put in the vehicle info. Either tell us which vehicle info to put in or find another link to what you're talking about.
  4. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
  5. shane74
    shane74 1/2 ton status
    Feb 12, 2002
    4,100
    Vancouver, WA
    Looks like wheel cylinder kits for the older style front drum brakes. Work just like rear wheel cylinders.
  6. 1977k5
    May 26, 2003
    9,995
    133
    The description says wheel cylinder left front. The wheel cylinder is the hydraulic actuator that makes drum brakes transfer force to the brake shoes. What vehicle did you select? Does it have front drums?
  7. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    Uh when you step on the brakes the fluid flows between the pistons and pushes them outward causing the shoes to contact the drum. The friction between the shoe and drum cause the vehicle to slow down and eventually stop.
    Ira
    Damn I am slow :(
  8. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    Ok, so these little wheel cylinders are what the fluid is pumped through...then they push the pads into the drums?
    Oh and the year didn't matter...I just put in a '78 K30...I just wondered what these were...I've had a few people tell me to replace them regardless of how mine look when I open up my 14ff in the next few days.
    -Avery
  9. 1977k5
    May 26, 2003
    9,995
    133
    Drum brakes have shoes, disc brakes have pads.
    They are pretty cheap and will probably ruin the shoes if they leak. Who knows how old they are and what shape they are in. For $12 a pop I would probably replace them.
  10. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Why not just go disks? ALOT easier to maintain and cheaper to.
  11. 1977k5
    May 26, 2003
    9,995
    133
    I thought about suggesting that too but he will lose his e-brake unless he wants to spend $$$. Plus if the brakes on it are serviceable the money for the conversion is another added expense.
    I had planned on keeping the drums on my 14 bolt for a while but when I found they were trashed there was no question discs were the way to go.
  12. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    b/c money is running low quickly w/ this project and Thanksgiving break is next week...my only open window where I don't need the truck to get to school and I have a couple days off of work.
    My plan is to get the 14ff in first and get the lines hooked up for the brakes...then get the front 10b in and hook up the lines and the steering.
    Then put the new 1 ton MC in to replace my old smaller master cylinder then have a buddy come over and help me bleed the system.
    From there I'm going to get the tires onto the new rims and I'll be ready to go....
    So its a full load of stuff to get done in a few days for a rookie...I know its easier while its out but financially and time wise I just don't have the means to do a disc swap right now. The drums will have to do.
    Now the only thing left to get is some big blocks to help raise my jack stands since they are too short to pick the truck up by the frame...so I'll get those tomorrow at the lumber yard across from where I work....and get the brake situation worked out, the fronts are fine but one of the rear drums is sticking so I'll figure out whats up w/ that this weekend. I was asking b/c I didn't know if I should order a set for the 14ff so that they can get here in time for the weekend or if I just shouldn't worry about it.
    -A
  13. jekquistk5
    jekquistk5 Weld nekid Premium Member GMOTM Winner
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    Did you pick up "Wheel cylinders" for the 14? If you haven't you better. I thought I allready explained that in one of your other posts!
  14. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Yes, definetly replace them. I had one go bad in my 12-bolt and found out that the brake fluid will melt the compound that the shoes are made from. :eek1:
    It easily turned a 30 minutes job into a 4 hour one just cleaning all that black goo out. :( :doah:
  15. K5er4Life
    K5er4Life 1/2 ton status
    Oct 16, 2002
    1,456
    Bellflower, Ca
    Yeah Avery replace the wheel cylinders (the things you posted). They are really cheap and provide good piece of mind. I would say 99 percent of my brake failures that I have ever had came from a leaky wheel cylinder. Then all the fluid goes bye bye and you have no brakes. I had a 95 f-150, I was going out riding so I was hauling ass down the freeway. Everythings great, going out riding, time to exit, apply brakes, SH*T, NO BRAKES! Scared the crap out of me. Luckily in the very last part of the stroke the fronts applied bringing me to a safe stop, nevermind the poo in my shorts.:blush: To make a long story longer, I ended up breaking my collar bone that day at the track and had to drive home with the truck like that because I couldnt fix it. Wow, what a day, but I ended up getting drunk later so everything worked out in the end. :waytogo:
  16. jekquistk5
    Jan 18, 2004
    11,026
    855
    Pinckney, MI
    They are sticking b/c of a crappy wheel cylinder!! Order them or pick up the wheel cylinders for the rear
  17. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    :haha:
  18. Avery4jc
    Oct 24, 2005
    10,760
    75
    Fresno, Ca.
    I sort of doubt this is from a leaky wheel cylinder...I shouldn't have said "sticky" but stuck...it won't budge, lol.
    Ok, so should I order them online or if I go to the parts store do they normally stock these? Oh and there were two things listed on that page from NAPA...a wheel cylinder then a little kit...can I just get the wheel cylinders or do I need that little kit too?
    Thanks guys!
    -Avery
  19. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Complete cyls if your name is Avery, kitz if jour name ees Manuel Labor.:haha:
  20. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    you're going to have it all apart anyways, dont mess with wheel cylinders, just disc it and be done with it. ruffstuff has brackets for $45, add a set of K20 calipers (~$20 each) and a pair of K20 front rotors (~$30 ea) superior braking is good, m'kay.
