whats under the dashpad
Discussion in 'The Garage' started by Big GMC truck, Mar 31, 2006.
  1. Big GMC truck
    Big GMC truck Registered Member
    Aug 23, 2005
    73
    California
    Is there sheet metal directly under the dashpad? I want to screw a tach on the far driver's side of the dashpad. 1984 gmc k1500 any pictures? Are there any wires that I could accidently screw into?
  2. goldwing2000
    goldwing2000 Guest
    There's a metal backer but it's really thin. Unless you screw it all the way into the dash under the pad, it probably won't hold. But I wouldn't do that, personally.
    You'd be better off drilling holes and nut&bolting it.
  3. Big GMC truck
    Aug 23, 2005
    73
    California
    How would I hold the nut? Wouldn't I have to take out the dashpad completely?
  4. NEK5
    NEK5 3/4 ton status Premium Member
    Oct 25, 2005
    9,843
    37
    Ipswich MA
    all you need to do is put a screw into the pad itself and use a washer under the head so when you tighten it, it wont go through
  5. goldwing2000
    goldwing2000 Guest
    Not completely. Remove the screws from the top of the IP bezel, remove the screws from above the glove box and you can lift it up enough to get a hand under.
  6. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    One way and you hit the speaker hole , the other and you hit the gauge cluster . You could like I did by bending a bracket and using a bezel hole . Or bend the bracket over the top of dash instead :thumb:
  7. goldwing2000
    goldwing2000 Guest
    Where there's a will, there's a way...
