What's up with my D-shafts?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77K5Blazer, Feb 10, 2002.
  1. 77K5Blazer
    77K5Blazer 1/2 ton status
    Mar 11, 2001
    255
    Hood River, Oregon
    What\'s up with my D-shafts?
    Ok, after putting my new lift springs in the front, I can't get my front driveshaft to slip far enough to reconnect it! WTF?? It's only a 4" lift! What do I do guys? I really don't have any money to get it extended. Also, is it alright if threads are showing on the rear slip shaft? Thanks!
    Allan
    <font color=red>1977 Blazer, GM350, SM465, NP205, D44/ 12b...4" TC Kit here, MT/Rs on the way</font color=red>
    <a target="_blank" href=http://community.webshots.com/user/blazinor>http://community.webshots.com/user/blazinor</a>
  2. reddog64
    reddog64 1/2 ton status
    Nov 9, 2000
    3,325
    Federal Way, Washington
    Re: What\'s up with my D-shafts?
    Superlift makes a 1 inch block you can put on the front driveshaft... 50 bucks...
    The rear.. well dont wheel it hard if you have rear blocks dont slam the brakes on... it'll pop out... trust me...
    I had about 1/2 inch showing and mine popped out when somelady cut me off and i had to lock them wheels up... not good...
    It's about 140-160 to lengthen the rear...
    Do It!
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    That's nonsense. I've been running rear blocks for a long time, and so have my buddies and a lot of other people. Springs or a shackle flip are better, but blocks are plenty safe. Even the factory uses them.
    Tim
  4. reddog64
    Nov 9, 2000
    3,325
    i never said they werent safe... you know what axle wrap is... blocks cause it... if your rear shaft is too short and you have a axle wrap problem the shaft can pop out.. you want pictures of what happens when the shaft pops out.. it rips things apart...
  5. Overkill
    Overkill 1/2 ton status
    Jan 15, 2002
    284
    Orlando, Florida
    I think Tim was thinking you meant that the blocks would pop out, not the D-shaft. I could be wrong but that's what I would guess by his answer. Just a thought.
    Jamie
    Pics at <a target="_blank" href=http://community.webshots.com/user/jlblmkh>http://community.webshots.com/user/jlblmkh</a>
    (Formerly heaj1)
    Swimmin like a rock, slingin like a stock, but not for long.
  6. Grim-Reaper
    7,385
    Atlanta
    Sounds like the splines are jammed. should be plenty of spline for a 4 inch lift. BigJBear had the same problem when he lifted his 80. Run it by a drive shaft shop and see if they can fix it. Most places will respline them for about $150.
    Women dig dents and flat paint!
    coloradok5.com/gallery/Grim
    75 Jimmy, Dollar
    Grim-Reaper
  7. 77K5Blazer
    Mar 11, 2001
    255
    Hood River, Oregon
    Thank you all for the help, I'll pull it and see what I can do about it! I got the spring part done tonight, it looks damn good sitting 4"s higher! Thanks again...
    Allan
