Whats up with my oil?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1979Jimmy, Nov 26, 2001.
  1. 1979Jimmy
    1979Jimmy 1/2 ton status
    Nov 14, 2001
    696
    Danville Ca
    I have been leaking oil latley but I cannot figure out where it is coming from. I just replaced my radiator and I think that it may be coming from the oil cooler in the radiator but i cant tighten the connections anymore. Its a slow leak but it has slowly covered all of my passenger side shocks and the passenger side of the axle. I am concerned about the ramifications of this. I dont know what to do. Anyone have any ideas?
    79 Jimmy, 5" lift 35 M/T with a 383 puttin out 400hp and 450lb/ft. Locked front and back.
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    may be a valve cover gasket
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Degrease your engine real well, then see if you can find it
    Don't hit me, Mr. Moderator... I'll go back on topic... I swear![​IMG]
    <a target="_blank" href=http://www.geocities.com/muddin4fun79blazer>www.geocities.com/muddin4fun79blazer</a>
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I've had the fittings that connect the rubber hose to the metal line start leaking on 2 different vehicles with the factory oil cooler option. [​IMG] GM is VERY proud of those lines too. [​IMG] You need to get everything very clean first, then it's much easier to locate the source of the leak.
  5. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    Try your dipstick tube if it is on the passenger side, I've had that happen twice.
    Rob
    <font color=orange>Bleedin' Chevy Orange</font color=orange>
  6. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    It all started happening AFTER I replaced the radiator. I think im going to try and get some ruber o rings to put down.
  7. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    Clean everything up real well, change your oil and add some oil dye. When it leaks again take a flourescent light and it will show where the leak is coming from. You could also take some teflon tape and wrap it around your fittings on the oil cooler. Maybe that will take up some slack.
    That jeep thing? Yah I understand it....... Like my Blazer? <a target="_blank" href=http://community.webshots.com/user/blazerk5>http://community.webshots.com/user/blazerk5</a>
    Jim
  8. 1979Jimmy
    Nov 14, 2001
    696
    Danville Ca
    Thanks alot.
  9. sarazk5
    sarazk5 1/2 ton status
    Feb 19, 2001
    713
    Sacramento, CA
    I finally got rid of all my leaks after doing valve cover gaskets, rear main seal, distributor ring, and oil sending unit. I also replaced my oil pan, but i don't think the old one was leaking.
    Anyway, my biggests leaking culprit was the oil sending unit. Oil was going right through it. It seamed like that thing got worse and worse as i fixed all the other leaks. Now it isn't leaking at all :-)
