Whats ur favorite spark plug lol
Discussion in 'The Garage' started by 85mudbogger, Mar 19, 2007.
  1. 85mudbogger
    85mudbogger 1/2 ton status
    Feb 5, 2007
    226
    missouri
    I have run the bosch plat 2, i disliked as for they liked to foul out and cold starting sucked
    I changed to champions and was a lot better but after about 6 months they also fouled out and starting was a little better but progressively got worse, i know some of this is due to 11 to 1 compression and 93 octane and the heads arent in that great a shape but when it runs it run like a scalded dawg and the champions just seemed to not hold up to the severe duty
    post up what ur running and why ur running them and how long have u had them,
  2. Pvt. Maggot
    Pvt. Maggot 1/2 ton status
    Sep 27, 2005
    559
    Brownsville PA
    I always rock ac delco's, cheap, and i've never had any problems with them.
  3. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    x2 ac delco's....
  4. thedrip
    thedrip 1/2 ton status
    Dec 13, 2003
    1,129
    Chattanooga, TN
    39c/ea regular cheapie house brand copper plugs. Gap 'em by eye or with a hacksaw blade, change them all out once a year. Always worked great for me, then again, I only own old beater v8 cars, lots of room to change plugs. If it was a 6 hour job to change plugs, I'd be ponying up for 100k mile whatevers
  5. camok5
    camok5 1/2 ton status Premium Member
    Jun 25, 2003
    959
    13
    Buellton, Ca
    I used to run NGK plugs in my 70 Camaro with a built 10.5 to 1 350 and they really seemed to work good.
  6. dyeager535
    26,982
    191
    Rumor has it that's who's making AC plugs nowadays, would make sense that NGK's work good. :)
    I use AC's as well. Got a screamin' deal on a bunch of them (24 or so) on ebay awhile back, like $.50/plug.
  7. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    i have always run AC delco in a vehicle and NGK in all my bikes.
    when the 454 is done, its getting NGK plugs.
  8. rick88blaze
    rick88blaze 1/2 ton status
    Jan 24, 2003
    2,342
    Knob Noster, Mo.
    X3... I've tried the fancy bosch plugs and they all fouled out on me within 6-8 months or so. I went back to AC Delco and don't have any problems. :D
    Rick
  9. 85mudbogger
    Feb 5, 2007
    226
    missouri
    seems like i be gettin some ac delcos or some ngks cant believe the votes for theses haha
  10. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    I'm happy with autolite plugs. Never had a problem, and have run them in just about every vehicle I've ever owned.
  11. 85mudbogger
    Feb 5, 2007
    226
    missouri
    how bout some part#s on ur ngks , which heat range u runnin
  12. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Ever since i first ran an NGK V-power plug about 15 or more years ago i will never run any other plug again.
    EDIT: Current engine uses a UR-5 NGK plug.
  13. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I use strictly AC Delco's, i have NEVER had a problem with them, and they last a good long time.
    I have tried the cheaper Bosch, Platinums, ones with multi points, whatever, nothing has lasted as long, and as well as the AC's have,,,,,well, there was one set, but i got those for free, :D
    I didn' notice any power increases, of fuel mileage gains, but they did work for their standard purpose of creating a stable spark, and actually i ran them for almost two years before i just decided to do a tune up> They actually were not that bad, the edged were alittle rounded, normal wear for a sparkplug though.........Splitfires.
    Too expensive to go buying a new set though especially when AC's did just about, if not the same job Splitfires did.
    So yeah, yet another vote for AC Delcos :D
  14. blazin_blazer
    blazin_blazer 1/2 ton status
    Aug 2, 2005
    4,043
    central arkansas
    i agree
    not sure if they still do it, but autolites used to carry a 100,000 mile warranty!
  15. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I am running Bosch now , and no problems , but will switch back to AC Delcos next change .
    When I was a kid , I swore by Autolite plug # 145 ( truck and marine ) in all my small blocks in AZ .
  16. NewUser
    NewUser 1/2 ton status
    Feb 13, 2007
    528
    Chattanooga TN
    ac delco here
  17. vortec
    vortec 1/2 ton status
    Jul 22, 2004
    1,472
    fort worth, texas
    im running 7 ac coppers (because i like them) and one bosch copper. cylinder 2 plug got hit with some offroad debris. what are the chances? i had my old set of bosch plugs (49cents apiece with coupon) with me for spares and popped one in. good as new. decent plugs. i'd have no problem running bosch again.
