what's with the squeek?
Discussion in 'The Garage' started by n8brown, Feb 22, 2006.
  1. n8brown
    n8brown Registered Member
    Dec 8, 2005
    23
    Portland, OR
    i have a pretty serious squeeking whenever i accelerate. What's the deal?
  2. chvymudin3388
    chvymudin3388 1/2 ton status
    Mar 3, 2005
    374
    orange grove ,tx
    oil your squirels cage... just playing but it might belts or it could be a bearing on the frits my belts are noisy i need to replace them or you could try sanding on the pulleys a little bit or put bar soap on the belts yes it realy does work lol
  3. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    My tailgate squeeks but only on bumps.
    Ira
  4. chvymudin3388
    Mar 3, 2005
    374
    orange grove ,tx
    yea something in the back of mine squeeks and drives me nuts i think its the spare tire and carrier my tire is to big to let it tighten and suck up all the way to the thing
  5. sweetk30
    Nov 1, 2004
    25,536
    533
    horseheads , ny 14845
    have you check the ujoints ?:confused: :wink1:
  6. n8brown
    Dec 8, 2005
    23
    Portland, OR
    the belts sound like a promising way to go. its only happening when i accelerate, could that still be a ubolt issue?
  7. sweetk30
    Nov 1, 2004
    25,536
    533
    most ujoins in the drive shaft make noise when under power like taking off. pop under the ride and look for major play and rust coming from the cap seals. if any of these time for reman for the shaft with new joints.
  8. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    you need to tighten your alternator belt using a pry bar.
  9. BIG*RED
    BIG*RED 1/2 ton status
    Mar 14, 2003
    1,094
    heres a thought, i had a similar problem..
    turned out that my speedo cable was worn..so i got a new cable, and the squeek went away.
    another thought is that it might be you speedo itself..somtimes you need to take them out and spray a little lube in the back of them where the cable hooks up
