What's with this 6 lug 14 bolt?
Discussion in 'The Garage' started by divorced, Jan 21, 2006.
  1. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    I found this on ebay while searching for a Ford 9" center section. It looks like a 14 bolt FF that isn't a FF any more. Does anyone have any info on these? I wouldn't buy the one in the auction, but I would like to convert my FF to a six lug pattern to use in my '96 K1500.
    http://cgi.ebay.com/ebaymotors/G-M-...cmdZViewItemQQcategoryZ33731QQitemZ2451878780
  2. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    Ive seen stuff like this that were 5 lug that they put under drag trucks. This is an expensive option that is used to keep the same lug pattern and wheels.
  3. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    Just looked, they basically just have new tubes welded in and put some sort of c-clip eliminator. Cant find much more with my resources
  4. divorced
    Jul 20, 2004
    5,115
    So, I'm guessing they cut the spindles off and welded on a different end to make it a SF?
  5. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
  6. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    odd.... like to know about the axleshafts. If they are still big or what. Would have to be at the spline end but who knows outward.
  7. divorced
    Jul 20, 2004
    5,115
    It still looks fairly big in the pics, but it can be deceiving. I really like the design of the FF axle, and I doubt using these 6 lug shafts would be inexpensive. Oh, what to do...
  8. sweetk30
    Nov 1, 2004
    25,540
    539
    horseheads , ny 14845
    for the price of those now semi floaters why not just get 6 lug hubs and save tones of money :confused:
  9. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    Exactly
  10. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    6 lug hubs for 14FF's aren't cheap, but they are purty!
  11. MNorby
    MNorby 3/4 ton status Premium Member GMOTM Winner
    Dec 10, 2001
    6,126
    53
    Powell, Wy
    ...or for the $$ just get some $50 each 8 lug wheels and be done with it.
  12. divorced
    Jul 20, 2004
    5,115
    Those hubs look awesome, Jason.
    I would, but my front is 6 lug and I'm not sure what it would take to convert it to 8 lug, and I'm really in to having the same lug pattern front and rear.
  13. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,081
    486
    Grand Rapids area
    I agree. Why convert to S/F at all? Either run a 9.5" rear or keep if F/F by getting the hubs done. Most people want disc brakes anyway and you can combine some of those costs.
  14. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Got the junkyard and strip everything off the knuckles of an 8-lug 10bolt or D44. Swap it all onto your axle.
    There are other ways you can mix and match parts, but in my book that is the easiest way. Especially to type out an explanation.
    I would go with the 10bolt, newer and bigger bearings. Plus I really don't like the older D44 external hubs.
  15. mrk5
    Apr 20, 2004
    12,332
    1,040
    Northern Colorado
    Awww, damn double post. Sorry!
  16. divorced
    Jul 20, 2004
    5,115
    Yep, I already have plenty of 8 lug front stuff for the solid axles. This is for my '96 K1500 with IFS though. I would love to go solid axle on it, but the end of the frame where the bracket goes is bent from a minor crash, and I picked up a used 6" IFS lift for next to nothing and already have some bling-bling 6 lug wheels with 36" Iroks on them. I guess I'll worry about it when the monster 10 bolt blows up... and maybe find a factory 14 bolt SF 6 lug axle.
  17. neverendingproject
    Jul 24, 2005
    1,637
    Tulsa, OK
    you can also get a 14sf and get shafts and even disc brakes form black widow performance. My shafts were cheaper than stock shafts and mine are 4340.
  18. bigjbear
    Feb 18, 2000
    13,970
    451
    Marietta GA
    The stock 6 on 5.5" SF14 bolts are common/cheep enough. The only problem is finding the ratio you need. Or at least that was the only problem I had w/ my '95. It really is a bolt in swap; conversion u-joint or swap the yoke, and use the spring plates from the doner truck. Plus the bigger breaks are nice.
  19. edy k
    edy k Registered Member
    Dec 2, 2005
    5
    san marcos ca
    funny. just got a 70 k5 and it has a 6 lug 14 bolt have not got time to
    check it out will find out tomorrow
  20. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    someone swaped that in, its not stock
