Whats wrong with it?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 90K5, Dec 6, 2000.
  1. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    I had thought my fuel pump was going out. A few days ago, something happened and my truck stalled every few seconds. The fuel pressure was a little below specs, but just a little, nothing serious yet. Anyway, I found out the ignition module went out. It also went out back in July and I got a new module, coil and pickup. It sounds like something in the distributor is frying the module. Does anyone know what it could be?
    90K5
  2. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    I believe it is a good idea to use a heat transfer type of gell or grease under the distributer module to help conduct the heat away. The module generates it's own heat and has to get rid of it, or the life will be shortened. Did you use that stuff?
  3. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    No, where do you get it?
    90K5
  4. CK5
    May 19, 1999
    21,623
    701
    CO
    I just replaced the ignition module in my Blazer and the gel came with it. You should be able to pick some up at any parts store.
    Steve
    1990 K5 with stuff
  5. DMK
    DMK 1/2 ton status
    Feb 20, 2000
    757
    CINCINNATI, OH
    Just ask for dialectic grease, the grease serves as a heat sink. New moduale should have come with it.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    it should have came with it but if i didnt just go to the parts store and tell them it didnt come with any and they should just give you some
    s.smith 77blazer lookin 4 mud
  7. Wheels
    Wheels 1/2 ton status
    Aug 18, 2000
    638
    Heat sink paste(White paste that won't wash out of anything and a little smears forever) and Dieletric grease (Same color) do two totally different things. Heat sink pastes conducts and transfers heat, where as dieletric grease acts as an insulator to prevent arc over. It will harden when exposed to heat. If heat is your problem, get heat sink paste and wear latex gloves when putting it on or two months from now you'll be saying "Damn, where did all this white paste come from". Okay, that's my .05 and over 20 somethings years in electronics worth.
  8. 90K5
    90K5 1/2 ton status
    Jun 1, 2000
    3,719
    Lubbock, TX
    Well I found out something is burning out the modules, and something is wrong with the windings in the distributor. I hope this is the only problem...
    90K5
