Whats wrong with my Spedometer?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 78Blazer, Mar 15, 2001.
  1. 78Blazer
    78Blazer 1/2 ton status
    873
    Michigan
    Ok when I was driving my 78 the speedometer quit working I thought it was the cable but never messed with it, Now that I have tore it all apart and put it into my 84 with a new cable it still does not work. I know the cable and guage are good so what else can cause this?
    Scott
    78blazer
  2. jimmyjack
    jimmyjack 1/2 ton status
    May 11, 2000
    2,290
    Tucson Az
    It sounds like the speedo gear in you t case might be bad.
    creepin' and crawlin'
    Jim
  3. 78Blazer
    873
    Michigan
    Whats involved with this and how hard is it to change?
    thanks
    Scott
    78blazer
  4. bigjbear
    Feb 18, 2000
    13,970
    449
    Marietta GA
    If you have it hooked up to an old style cruise control this could also be the problem. It will be on the L/H inner fender. The gears in there can get stripped or jammed.
    Jim '80 GMC
    Freedom First!
    <A target="_blank" HREF=http://www.bigjbear.coloradok5.com>http://www.bigjbear.coloradok5.com</A>
  5. 78Blazer
    873
    Michigan
    I no longer have cruise on it all that was taken off it just goes straight to the tcase.
    Scott
    78blazer
  6. muddin4fun
    muddin4fun 3/4 ton status
    Feb 19, 2001
    5,644
    N Texas
    Pull the speedo out and drive it and see if you can see the cable spinning. If it does, you either don't have the cable pushed in all the way or your speedo is screwed. If it doesn't spin, then it's a gear in your t-case.
    [​IMG] Keep your feet dry [​IMG]
    <A target="_blank" HREF=http://muddin4fun.coloradok5.com>http://muddin4fun.coloradok5.com</A>
  7. Ditchdigger
    Ditchdigger Registered Member
    Mar 11, 2001
    96
    The Great Midwest
    Betcha, its your gears assuming you've checked your speedo
    and cable make sure the cable ends fit right and put a little grease in there!
