What's wrong with my tire?! POS!
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BLzr4x4ngkid, Aug 5, 2001.
  1. BLzr4x4ngkid
    BLzr4x4ngkid 1/2 ton status
    Feb 18, 2000
    703
    Wichita, KS
    What\'s wrong with my tire?! POS!
    I just took my truck on the highway for the first time since I dropped the 14 bolt in and the right rear tires still wobbles like it's unbalanced. The other thing is, none of the tires are balanced, but I don't have a problem with the others. Could there be something wrong with the tire? All but one of the tires wobbled with the 15x10's, so I figured it was just the rim. Even with new rims, that one tire wobbles. It's really starting to piss me off, because I can't drive it at 60 without the whole thing shaking!
    Pedal mashed and KICK'N ASS!
    WFO! Wide [censored]'n OPEN!
  2. Chris Demartini
    2,406
    Dumont NJ 07628
    Re: What\'s wrong with my tire?! POS!
    <font color=blue>What tires are these? My dad just got 38x15 bias TSLs and it shook bad. He tried to balance them but it was actually worse. Take it to a 4WD shop and see what they can do.</font color=blue>
  3. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Big tires are hard to balance in a conventional manner. To get them right you need to use a balance patch glued to the inside of the tire. to save me a bunch of typing go to this web site for a full explaination:<a target="_blank" href=http://www.intercotire.com/suggestions_for_mounting_and_bal.htm>http://www.intercotire.com/suggestions_for_mounting_and_bal.htm</a>
    You need to go to a tire shop that specialises in oversize tires to get this done.
  4. MudNurI
    MudNurI 1/2 ton status
    Jul 15, 2001
    2,113
    VT
    just curious, why would you put tires on a rig that aren't balanced? am i missing something here?
    1986 K5 4" skyjacker suspension 3 " body, 14 bolt rear, dana 44 front, TIRED ol 305
  5. LA Bogger
    LA Bogger 1/2 ton status
    May 19, 2000
    192
    Robins AFB, Georgia, USA
    Welcome to the world of running BIG Bias Tires. Get them balance I've had the best luck with 39.5 with tire companies that balance truck and tractor tires... And sometime you just get one out of round....
    Eat More Mud!!!
    Dreaming of a BIG BLOCK!!!
  6. Bubba Ray Boudreaux
    Bubba Ray Boudreaux 1 ton status
    Jan 21, 2001
    20,716
    Undisclosed Location
    When I worked in a tire shop, they would tell me that within .5 an ounce on a truck tire is good. One day, I brought my truck in (33 BFG MTs on 15x8s with one wheel bent) and took about an hour to balance all five until each and every one zeroed out. Yes, I have some places where there's about 5 ounces but sure did help the ride.
    Bubba Ray Boudreaux,
    Leader of the Advance Party for
    the CSA revolution in the PRK!
    <a target="_blank" href=http://www.handguncontrolinc.com>www.handguncontrolinc.com</a>
  7. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    None of my BFG Muds took more than 3 or 4 ounces.
    Tim
  8. riz
    riz 3/4 ton status
    Mar 7, 2000
    6,026
    Wisconsin
    <font color=purple> Are you sure it's one of your tires ? Which one is it ? Could it be one of your front axle shafts ? I've got some info for you maybe, but I need more info from you.
    L8r,
    . Riz . <a target="_blank" href=http://www.geocities.com/rizmonkey>www.geocities.com/rizmonkey</a>
  9. BLzr4x4ngkid
    Feb 18, 2000
    703
    Wichita, KS
    I'm running 16/38.5-15 TSL's. All the tire shops here in Wichita said they can't balance them, but they can mount them. The only one that's giving me hell is the right rear. This same tire shook really bad on the junk 15x10's and I thought it might be the crappy wheels. Well, I have brand new wheels and still have the same problem with this one tire. It even did it on the 1/2 ton rear, now I'm running the 14FF.
  10. jarheadk5
    jarheadk5 1/2 ton status
    Mar 6, 2000
    4,389
    PA
    OK, if it's the same tire doing the same thing on a different wheel, on a different axle, then the problem is definitely the tire. As stated before, sometimes you get one out-of-round.
    Something you could try is to use a tread depth gauge and measure the tread depth all the way around the tire. Hold the gauge the same way for each measurement, place it on the lugs the same way each time, and have an assistant write down the measurements. Or maybe you could cobble up a super-sized runout gauge, jack up that wheel, and spin it by hand and see if maybe the tire really is out-of-round. In any case, call whoever you bought the tires from and see if they'll replace it for you.
    It's always darkest just before it goes pitch-black...
    [​IMG] <font color=green>Semper Maintenance!<font color=black>
  11. Prembird
    Prembird 1/2 ton status
    May 15, 2001
    811
    kc, mo.
    What i would do is just swap the rear tire with one on the front... if the problem then moves with the tire then you know what it causing it.. if it still stays in the back then you got other problems...
    Prembird
    [​IMG] <font color=blue> If it aint</font color=blue><font color=red> LOUD </font color=red><font color=blue> Then turn it </font color=blue><font color=red> UP</font color=red> [​IMG]
  12. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    As stated before, if you move the tires around on the vehicle and it changes each time you move them, then it is a tire (or tires), but if it stays the same (say left rear), then I would say your bearings are shot, not torqued properly, or you have a bad drum (which has been known to happen).
    If you didn't build it yourself, how can you call it yours.......?
