What's wrong with my Transfer Case??? Grinding in 4-Lo.............
Discussion in 'The Garage' started by 81jimmyslt, Jun 29, 2004.
  1. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    What\'s wrong with my Transfer Case??? Grinding in 4-Lo.............
    Well first off I have an 81' 350/350/NP-208.
    Went wheeling today and when I shifted into 4-Lo from 4HI I got major grinding when I started to drive. I put it in reverse and even worse so I through it in nuetral and put it back in HI and drove out of there. When I got to the bottom I wanted to watch the linkage when it shifts but it just started grinding when it tried to shift in low. Left it alone and drove home /forums/images/graemlins/frown.gif
    I was hoping my linkage wasn't adjusted and slipped, but I don't think so.
    Before everything worked fine and I haven't changed anyhting since last time wheeling in LO
    I have always had problems with it falling out of gear, so I use a bungee cord to hold it where I want.
    Any suggestions???? /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
    Jesse
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Re: What\'s wrong with my Transfer Case??? Grinding in 4-Lo.............
    My first guess would be that you ruined the shift forks by using the bungee cord. /forums/images/graemlins/frown.gif They aren't designed to be held against the moving parts inside the case. /forums/images/graemlins/eek.gif
  3. Storm Trooper
    Nov 24, 2000
    4,640
    I'd agree that the shift forks are done. Find a good tranny/transfer case shop and go see them. They will tell you with a quick test drive.
  4. beatup4x
    beatup4x Registered Member
    Jun 17, 2004
    7
    Mountain Home AFB, ID
    What would cause a t-case to jump out of low range? Mine does this also sometimes. Sorry for the hijack.
