whats wrong with this dana 60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k5texan, Mar 3, 2002.
  1. k5texan
    k5texan 1/2 ton status
    Aug 1, 2001
    119
    Flint, TX
    i found an add in the back of my magazine about military surplus axles and i emailed them and this is what they said
    dana 60 front with 5.87, closed knuckle, drum brakes, 6 stud, used---$295 each
    matching dana 70 rear with 5.87 ---$500 each
    There is a disc brake conversion kit available
    FOB Akron, Ohio. Subject to prior sale.
    Let me know.
    Robert
    Sam Winer Motors, Inc
    3417 E. Waterloo Road
    Akron, Ohio 44312
    330-628-4881
    330-628-0948 fax
    why are they so cheap and i think they also 410 gears
    jared
  2. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    I would bet that they are m715 surplus axles, I don't know how hard they would be to fit to a chevy
  3. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    From what I understand closed knuckle axles are weaker then open knuckle units. Also the drum brakes make them less disirable. The 6 stud wheels will probably be the military style, not the 6 stud style on a normal K5, which would require special wheels and tires. So basically it will end up costing you alot of $ to make it like a normal D60.
  4. k5texan
    Aug 1, 2001
    119
    Flint, TX
    alright it had my hopes up for a second but i knew it was probaly to good to be true. sothe search continues.
    thanks
    jared
  5. dysphemism
    dysphemism 1/2 ton status
    Oct 26, 2001
    667
    Fremont, CA
    ya drum brakes and closed knuckles. They arent nearly as strong as a newer 60.
