What's wrong with this picture?
Discussion in 'The Garage' started by ak bandit, Sep 28, 2005.
  1. ak bandit
    ak bandit 1/2 ton status
    Sep 10, 2004
    386
    Eagle River, Alaska
    If you're facing the front of the engine, the fan spins clockwise right? My alternator fan spins counter clockwise? Or do I have the wrong water pump fan? :confused:
  2. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    Flip the fan around :dunno:
  3. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    That was my first thought when I looked at the pic.
    oh ya
    :bow: :bow: :bow: :bow:
  4. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    That was also my first thought, but wasnt sure...So if you're looking at the front of the engine, the fan spins counter clockwise?
  5. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    Cant see it, to much bling :p:
  6. ntsqd
    ntsqd 1/2 ton status
    Nov 28, 2002
    3,381
    So. CA
    Check a stock alt fan, it's the same way. They actually suck thru the alt from the rear. I'm guessing that's to keep the junk from going thru the alt since it won't easily make the 180* turn.
  7. ak bandit
    Sep 10, 2004
    386
    Eagle River, Alaska
    I just found a picture of my old engine...It appears that the fan on the new engine is installed correctly.
  8. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    Think about that alittle harder,,,it doesn't work that way
  9. BigCountryx
    BigCountryx 1/2 ton status
    Feb 19, 2005
    519
    Gonzales, LA
    "If your looking at the front of this engine, whipe the drool off of your chin." I Likey what I see!!
  10. 4xcrazy
    Oct 31, 2003
    9,472
    5
    "whats wrong with this picture?"
    ACTUALLY !!
    whats wrong, is it's not sitting under the hood of my Burb :doah: :D
  11. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    read it!
    Many fans I've removed have the word "FRONT" stamped into the hub where it bolts on... :whistle: ...if your still in doubt,(if its not marked)--just start it up--if it blows towards you instead of the motor,its wrong!.. :crazy:
  12. divorced
    divorced 3/4 ton status
    Jul 20, 2004
    5,115
    ... but simply bolting it on the other way will make it look just as it does now, and still blow the same direction. To actually change the direction of airflow you would have to reverse the rotation of the blade or change the pitch of the blades to opposite of what they are now (but simply "flipping" the blade around doesn't change the direction of airflow.) Just a friendly FYI. ;)
  13. diesel4me
    Jul 24, 2003
    17,583
    945
    Massachussetts
    by "wrong",I meant..
    What I meant by the blade being "wrong",is that it would be a "reverse rotation" if the air flowed away from the motor,and you'd need a "standard rotation" blade.. ..I know what your saying,the blades have to be offset the "other" way.... I've been guilty of bolting stock rigid blade fans on backwards when I was in a hurry,and had a few beers while wrenching!.. :blush: :tongue1: --when I removed them,thats when Isaw "FRONT" stamped in the hub.. :doah: :crazy:
  14. jms0966
    jms0966 Newbie
    Sep 20, 2005
    pittsburgh pa.
    looks like your using serpentine belt instead of v-belt. on serp belt there should be tension wheel to keep belt tight. with serp belt ,depends on how belt is run which direction accessories turn
  15. original balzer
    original balzer 1/2 ton status
    Nov 17, 2004
    4,660
    roosevelt utah
    WOW crap thats alot of confusion hopefully this will clarify. after looking at the engine it is correct.
  16. chevyin
    chevyin 1/2 ton status
    Sep 14, 2005
    1,324
    Pismo Bch CA
    I bought a chevelle several years ago that the guy had freshly rebuilt the engine and had put a flex-fan on it. First time I got it rolling I took it out in front of the house and dumped the cluth to lay a little rubber. :D Turns out the guy had mounted the flex fan backwards, Id never noticed, and that first time I got on it it flexed forward enough to chew up the brand new radiator. I can laugh about it now.
  17. RustyParts
    RustyParts 1/2 ton status
    May 26, 2005
    235
    Wyman, Kentucky
    Radiator fan is on backwards. Flip it over. Heavy edge cuts the air.
  18. wasted wages
    wasted wages 3/4 ton status
    Dec 3, 2003
    9,194
    Dallas Texas
    fan blade
    The engine rotates clockwise looking at the front of it.
    The fan is on correctly.
    Flipping it would put the curved part of the blade facing the engine and will not move any air rotating clockwise.
