Whats your best 1/4 mile time? Yes I said 1/4 mile
Discussion in 'The Garage' started by beastofablaze, Sep 4, 2006.
  1. beastofablaze
    beastofablaze 1/2 ton status
    Apr 4, 2005
    441
    CA
    I plan on going with afr 180s and a smog legal tq cam and desktop dyno says 430 hp and 461 ft lbs with tq curve like a ruler http://s89.photobucket.com/albums/k214/beastofablaze/?action=view&current=AFR_SBC2.jpg&refPage=&imgAnch=imgAnch1. I am kind of curious as to how fast we can get one of these chunks of iron to go in a 1/4 mile after hanging out on thirdgen.org since all they care about over there is 1/4 mile times.
    Yeah Yeah I know its a truck it weighs 5000 lbs blah blah blah....
    But what is your best 1/4 mile time if you have one.
    Be kind of cool if we could blow off a stock thirdgen as well as run over it.:D
  2. supersize75k5
    supersize75k5 OrganDonorRacing.com
    Feb 3, 2004
    8,832
    4
    gilbert az
    yikes.. slowwwwwwwwwwwwwwwwwwwww
  3. redneckdude
    redneckdude 1/2 ton status
    Feb 21, 2004
    578
    Augusta, GA
    17.9 at 71 mph...40s kill top end accelleration
    it was something like 11.7 @ 59 in the 1/8th tho...not great but not bad for a fairly stock 350 in a blazer on 40s...
  4. SkysTheLimit
    SkysTheLimit 1/2 ton status
    May 23, 2003
    530
    Tampa, FL
    Well, for giggles when I get it all installed, i'm going to run my K5 down the track. The motor thats going in came out of a drag camaro that would run low 9's. I'm going to try to find one of the simulators and plug in the hp, gears and weight and guess my quarter mile time. i don't care about beating a camaro or a stang but i do want to hand a ricer his a$$. just once. then i'll go back to the mud.
  5. tiger9297
    tiger9297 1/2 ton status
    Jul 23, 2004
    1,205
    Tupelo, Mississippi
    If you don't mind when you find the calculator post the link. I'd like to plug my info in too just for kicks.
  6. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    http://www.geocities.com/motorcity/4601/hpcalc.html
    scroll down to the third one. pretty generic but should be good for a ballpark.
  7. redneckdude
    Feb 21, 2004
    578
    Augusta, GA
    that thing ain't too far off. I put in 5200 lbs (not sure how much it weights in street/trail trim...had all my tools and crap in it at the time), 180 hp (should be close to my RWHP) and it was pretty close to what i ran a few months back.
  8. kawijames
    kawijames Registered Member
    Aug 14, 2005
    8
    texas
    pretty close
    yup its pretty close. ran against a friend of mine (runs 13's) was about a sec behind him. i guess that puts me at mid to high 14's. the calc puts me at 14.8
  9. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    Cool... I'm encouraged then, I liked the numbers it gave me.
  10. yoshisv
    yoshisv 1/2 ton status
    Feb 19, 2006
    266
    Hartsville, Tennessee
    Dont keep us waiting, What numbers did it give you?:confused:
  11. beastofablaze
    Apr 4, 2005
    441
    CA
    13.5 for a 5500 pound truck with 430 hp? Don't stock zo6 vettes run like 13's I mean the older ones... I'd think it would be more like mid to low 14's once you add in the 35's. But I like those numbers... and oh yes I want to make a few ricers cry too.
  12. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    It said 11.65 @ 5200lbs but I'll believe it when I see it. Even fudging it to mid 12's i still don't buy it. the new shelby cobra GT500 don't even run that.
    I'm going to have a video done when I go just in case it surprises me and the cobra i'd be running against. Maybe i should just hold on the n2o kit i have... on the bottle it says i could do 11.1.
    time will tell
  13. beastofablaze
    Apr 4, 2005
    441
    CA
    damn man what kind of numbers are you making? I'm guessing your running a carb
  14. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    The 496 I'm in the process of dropping in is supposed to be putting down a tad over 800hp and it has a 150 shot of juice on it now to boot. It's got a holley 4050 series on it now. peak power is at about 5k but it still respectable off idle. im not into the rock crawling (no rocks to crawl in FL anyway) so i went with something in the higher rpms to play in the sand and mud. kinda similar to drag racing so why not get a drag racing motor?
    plus, i gotta do some burn outs to make branndon proud..
  15. Ryan B.
    Jul 18, 2001
    5,693
    CA
    800HP? :bow: Got any specs on that 496?
  16. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    got a build sheet somewhere. don't remember all the little specs like cam duration and all that. the biggies are balanced rotating assembly, forged everything, aluminum heads are fully cnc'd and port matched. 10.5:1 compression. lopey as hell tho.
    i wanna be in the same league as Project Torque. :)
  17. SUBFAN
    SUBFAN 1/2 ton status
    Mar 23, 2003
    2,334
    Davenport, Ia
    Better look for a different tranny to hold all power....
    Or just give us pics of that split up the middle 700R4....
  18. uao85
    uao85 1/2 ton status
    Jan 2, 2004
    1,867
    Edge of insanity
    The 04-down z06's were a tad faster, I believe the quickest stock paper filter time I saw over on the ls1tech board was like 12.7 thereabouts. The new c6s are definitely breaking into 12s in stock form, and at the pinks show this past weekend there was a new c6z06 on a 100 shot and MickeyThompson et streets that ran consistant low 10 second passes all night long, was black on black to boot, that was a beautiful car. BTW if you manage to hook up on a track with all that power, not doubt you will break 11s. When you make it to the track, please take a vid of you smoking a vette or something cool like that.
    Remington
  19. SkysTheLimit
    May 23, 2003
    530
    Tampa, FL
    I was going to swap in the built TH400 i have but i want to keep overdrive. I'm going to sell the 400 and use the $$ to build the 700. It's a newer 700 and with the right mods it'll handle the power.
    there will be video made and posted whether i win, lose or break something. :D
  20. 1985_K5_Silverado
    1985_K5_Silverado 1/2 ton status
    Dec 21, 2005
    984
    Corn Country
    I'm a big fan of well-beefed 700R4 trannies, but 800 actual crankshaft HP (and in a heavy vehicle)...
