What's your crawl ratio?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 84_Chevy_K10, Nov 17, 2001.
  1. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    What\'s your crawl ratio?
    Just curious.
    Mine is currently 32.74, with 53.63 worth going in ASAP.
    How about you guys?
    Not that it matters, I rarely use low range anyway...not enough wheelspeed.
    Tim
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Re: What\'s your crawl ratio?
    Mine is 36.56. I use low alot (rockcrawling)and thats why I still have my 208. Some day I will get a doubler though.
    86Jimmy 4"&35"MTRs,87 burb 4"&35"MT,69Firebird w/525 hp,and 70GTO live in PHX,AZ<a target="_blank" href=http://www.geocities.com/modifierperformance>My vehicles</a>
  3. JunkYardCrawler
    JunkYardCrawler 1/2 ton status
    Sep 9, 2000
    575
    Tucson, AZ
    32.32:1 in first/second(what ever you call it). and 59.14:1 in first or low.
  4. jekbrown
    May 19, 2001
    45,031
    366
    Vancouver, WA, USA
    How exactly are these numbers computed? My tranny is 3.06 in 1st...x-case is a 208, I forget its 4wd low gearing...and I have 4.56s in my diffs... ? =|
    J
    See the on-going build up of my '85 Jimmy! http://community.webshots.com/user/jekbrown
  5. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    i forget the formula so i use <a target="_blank" href=http://www.4lo.com>www.4lo.com</a>
  6. tRustyK5
    Jul 23, 2000
    36,175
    1,385
    E-town baby!
    47.81:1 gotta love the SM465[​IMG]
    Jek...the NP 208 has a 2.61:1 low range. 3.06x2.61x4.56=36.42:1 crawl ratio
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  7. JunkYardCrawler
    Sep 9, 2000
    575
    Tucson, AZ
    oh yeah. i love mine[​IMG]
  8. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    36:1 in the Blazer-could definitly use more, its just on the edge of acceptable.
    The funny thing is the daily driver has a 54:1. The 154" wheel base kind of negates that, though.
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  9. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Mine is 18.42:1[​IMG][​IMG]
    and soon to be 22.52:1[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Gota love that 2:1 low range[​IMG]
    But at least I can go 60 on the fwy in 4 wheel Lo...don't ask.
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  10. Blazer_Boy
    Blazer_Boy 1/2 ton status
    Dec 16, 2000
    1,669
    Sioux City, IA, USA
    My pavement pounder has 30:1. Kinda funny cause I'm making a big fuss about putting in my new 12 bolt even though the 10 would hold up to what I do.
    3.06x2.61.3.73
    "I ain't nobody, dork."
    <a target="_blank" href=http://www.geocities.com/bigkern76>http://www.geocities.com/bigkern76</a>
  11. rock.monkey
    rock.monkey 1/2 ton status
    Oct 28, 2000
    296
    100 Mile house B.C. Canada
    Hummmm......70.2?
    Not bad
    Bill Innes
    88' Jimmy
    Built for <font color=blue>Function</font color=blue> <font color=red>NOT</font color=red> <font color=blue>Fashion</font color=blue>
  12. KENT
    KENT 1/2 ton status
    139
    Roseburg, OR
    66.45
    SM465/NP241/3.73 gears
    It is real nice to be able to creep along over the rough stuff.
    Kent
    1989 K5
  13. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Currently, the only thing crawling around here is me. Under the blazer at about 12 ft per sec...[​IMG]
    When I'm done, it should be 40.50 to one (with a doubler)
    T350/203/205/4:10 gears.
    or
    2:52 x 2.0 x 1.96 x 4.10 = 40.5 to 1
    Do you include the torque converter slip when useing an auto? Somethng like 1.8 to one I think for the converter.
    Than it would be 72.9 to one.
    <font color=blue>Twiz</font color=blue>
  14. K10ANDYKHAMNIC
    K10ANDYKHAMNIC 1/2 ton status
    Sep 17, 2001
    1,962
    Western CO
    i dono what mine is i have a th350 an np208 and 4.56s with 35s
    dents ....
    O R D's axles
    NO BREAKAGE :)
  15. mike reeh
    mike reeh 1/2 ton status
    Jul 23, 2001
    752
    San Diego, CA
    what does crawl ratio signify?
    and why doesnt it change with tire size
  16. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Crawl ratio = transmission 1st gear x transfer case low range ratio x axle ratios
    Mine is currently 3.06 x 2.61 x 4.10
    Soon to be 6.55? x 1.96 x 4.10
    Tim
  17. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Basicaly, I think it about the ability to crawl over, up and down objects in a contoled rate of speed.
    So you don't have to use momentum to get from point A to point B. (momentum is hard on parts, more so than torque. I would think) As you "gear down", torque is multiplied, and torque is what gets you moveing and keeps you moveing.
    Torque is the ability to do work (basicaly), more torque (out-right or by gearing down) the more work can be done.
    Tire size does have an effect on the crawl ratio, the larger the tire, the more ground is covered at the same R.P.M.. I don't know why it's not figured into the formula, probably due to too meny varaiables - I guess.
    <font color=blue>Twiz</font color=blue><P ID="edit"><FONT class="small">Edited by Twiztid on 11/17/01 11:36 PM.</FONT></P>
  18. XtrmChevy
    XtrmChevy 1/2 ton status
    Jul 14, 2001
    148
    Finland, Europe
    It will be 52,87
    1981 K20 350/400/208/205 D60fARB & 14bFFDETROIT 4.10 (UNDER CONSTRUCTION!!)
  19. RedDwarf
    RedDwarf 1/2 ton status
    May 9, 2001
    816
    North Central Florida
    63.72:1
  20. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    20.82:1
    -Zakk
    '77 K5 SB 400 TH350 NP203 p/t 6" Lift D60 14BFF 4.10's 36"Wrangler II's
    [​IMG] CK5's MOAB 2002 OR BUST!! [​IMG]
