What's your experience with painting/dying dash and interior?
Discussion in 'The Garage' started by wy4tt, Jun 12, 2005.
  1. wy4tt
    wy4tt 1/2 ton status
    Feb 20, 2005
    153
    USA
    Just wondering if you guys have had luck with it sticking. If so, what's the best prep/method to use? Also any recommendations on brand/type of paint. Thanks guys!
  2. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i just got done doing mine black with the rattlecan SEM.. looks great, sticks fine... i just scrub everything down well with denatured alcohol for prep.. you can also buy vinyl dye in qrts from PPG, etc....
  3. wy4tt
    Feb 20, 2005
    153
    USA
    Thanks Ryoken. Did you use Sure-Coat?
  4. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    i used colorcoat... in semi black.... 2 or 3 coats and my tan is now black.. :D
  5. WhiteBurb
    WhiteBurb 1/2 ton status
    Mar 10, 2005
    307
    Louisiana
    Don't skimp on the paint. The vinyl paint at Walmart will look tempting because its so cheap, but it isn't good for large areas.
    I used the VHT vinyl dye and it worked great. Definitely prep the surface really good. I scrubbed my parts with soap and water, then cleaned it up with some xlyene I had in the garage. Then gave each piece 3 light coats.
  6. wy4tt
    Feb 20, 2005
    153
    USA
    Thanks guys. Whiteburb, how long have you had the dye on?
  7. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Painting I had good luck on all pieces except my door panels and armrests. Probably because they are high use areas, but the paint has cracked some. Will probably redo, or replace them in a yr or two when they crack up alot. Its not the plastic cracking, but the paint.
  8. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    Its been over a year. But I didn't bother with the door panels, I'm just going to replace those. I didn't think the paint would like such high use areas.
  9. cybrfire
    Dec 15, 2002
    15,142
    572
    Iowa
    There some fairly new stuff out there, not sure the brand but it's called Infusion. Maybe Krylon. Heard good things about it. Gona give it a try. I still think the high use areas such as top of the door panel and arm rest I'll upholster for longevity. Top of the door panel I think I'll talk the wife into making me a pad to velcro on. Sort of an upper arm rest.
  10. dodgedude99
    dodgedude99 1/2 ton status
    Jul 12, 2003
    784
    burbia of illinois
    when i changed my awesome Burgandy interior (i never understood blue or red interiors) to black, i didnt have a problem with anything except the door panels. everything else took color great except for them.
    i tried SEM, VHT, Duplicolor, all the various sticking compounds, hell i even washed the panels down with soap and water, denatured alky, and laquer thinner. the only thing that stuck was the Krylon Infusion. now my sons S10 door panels, the Duplicolor worked great.
  11. wy4tt
    Feb 20, 2005
    153
    USA
    Thanks for all the info guys. I agree, the door panels are going to be the tough part. I'd almost just get new ones if I could. My interior is burgundy as well and it's going black.
    What about the paded panels on the sides in the rear/bed? Do you do those the same as what's up front?
  12. dodgedude99
    Jul 12, 2003
    784
    burbia of illinois
    my k5 didnt come with rear panels. i scrounged one from a junkyard, and used it as a template for some 1/4" plywood.
    i then covered it in "Pleather" and made a particle board raised panel with a hole for a 6x9 where your knee would be and a groove for a piece of aluminum trim, then covered it with Zebra Velvet. :D
  13. wy4tt
    Feb 20, 2005
    153
    USA
    Very nice. I'm thinking of changing the color of the Jimmy, but it's burgundy and the interior matches. So...
    I don't mind the original color much, but whoever repainted it did a crap job and it's more brown than burgundy on the exterior.
  14. WhiteBurb
    Mar 10, 2005
    307
    Louisiana
    For the walls in the back, I got some of that thin particle board stuff. I can't remember what its called(I want to say masonite), but its dark brown and only about 1/8" thick. Got it at Lowes. I cut the pieces to fit and carpeted them.
    I pulled the lower door panels all the way out and bedlined that portion of the door.
  15. oldassjeep
    oldassjeep Registered Member
    Oct 21, 2004
    84
    Burnet TX
    As far as my dash goes, it was very cracked and faded. I took it with the door panels to a local upholstery shop and had the dash covered in marine grade vinyl. Same material as the seats and the door panels. I could send pics if anyone would like to see. looks good but it has a seam on the gauge "hump". Doesn't take away from the look of the dash either.
  16. SUB-ZERO
    SUB-ZERO 1/2 ton status
    Oct 8, 2002
    219
    Virginia Beach,Va.
    I bought a new dash but I spray coated the door panels with duplicolor and I was very careful to clean them well with alcohol first and three light coats of color.They looked like new at first but after about 2 months of heavy wheelin' and pressure washing they look like dog doo!I am thinking about having them Line-x'ed(the rest of my truck already is).
