What's your oil pressure?
Discussion in '1982-Present GM Diesel' started by tRustyK5, Nov 2, 2003.
  1. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    What\'s your oil pressure?
    Finally got my oil pressure and other guages working...
    Fired it up cold (ambient temp was 38 F) and my oil pressure was 47-50 psi. Once it warmed up it dropped to 35-38 psi at idle. If I gave it a few R's it climbed to mid 40's.
    Is this about average for a 6.2 with 220,000 miles?
    Rene
  2. joez
    joez 1/2 ton status
    Oct 21, 2003
    2,512
    New Lenox, Illinois
    Re: What\'s your oil pressure?
    i was going to ask the same question, cause mine does the same thing. only after about 2 hours of driving, it drops to about 30 at idle, and then back up to low-mid 40's when driving.
    my toyota did this, and it seemed to vary even more than the diesel.
  3. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Well, I may moderate this forum but most of this is still quite new to me too. I'm just kind of interested what an average 6.2's oil pressure would be to guage my own.
    Hopefully we can get a good sampling...
    If it was a small block I'd say my oil pressure is great /forums/images/graemlins/smile.gif
    Rene
  4. Tybee
    Tybee 1/2 ton status
    Mar 25, 2001
    1,565
    Centennial, CO
    I think mine stays around 40 but I really dont look at it that much. Ill look at it tomorrow.
  5. Can Can
    15,555
    156
    Cochrane, Alberta, Canada
    With relatively fresh oil, my needle sits about 3/4 of the way up the gauge until the motor is warm. Once warm it floats between 2/3 and 3/4s depending on RPMs. Even during hot operating conditions(like towing), it never drops below the halfway mark at idle.
    I'd like to give you some PSI readings to compare to but you know that the Canadian trucks read in KPAs and I'm not smart enough to convert them. I do know that 770 KPAs is 112 PSI, though. That's what I pressure-test all my underground installs at. /forums/images/graemlins/rotfl.gif
    My 6.2 has about 125K miles on it, BTW.
  6. ducttape114
    ducttape114 1/2 ton status
    Aug 1, 2002
    990
    Orcutt Ca
    my 6.5 runs at 20 at idle. about 60 at free way speeds. but that is going off a factory gauge that i dont completly belive.
  7. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    The 275 kpa mark is 30 psi. 550 kpa is 60 psi. I don't know how well that jives with the math but the guages are most likely identical except for the stencilling. I really doubt they changed much else... I just swapped the metric gauges out for some imperial guages I had in another cluster. Now my oil pressure and temp is imperial and my speedo is still metric as is the odometer.
    So far it sounds like mine is in the normal range for it's mileage.../forums/images/graemlins/thumb.gif
    Rene
  8. DieselDan
    DieselDan 1/2 ton status
    Jan 27, 2001
    1,056
    Vermont
    IIRC all of the later 6.5 (turbo) blocks have piston oil squirters, that shoot oil on the under side of the piston. This really drops the oil pressure at idle /forums/images/graemlins/shocked.gif
    My '89 6.2 runs 60+ psi cold then will drop to 40+ at hot idle. /forums/images/graemlins/thumb.gif
  9. BlueBlazer
    BlueBlazer 1/2 ton status
    Feb 15, 2001
    1,940
    Both 6.2s I have owned would get to a max of 70 psi on cold days and by the time they warmed up would hover around 40 at idle with maybe a 10 psi increase on the highway.
  10. ducttape114
    Aug 1, 2002
    990
    Orcutt Ca
    well im non-turbo'ed. i dont know if they would have still used the same block thou. its a newer GM crate motor, 98ish. should i be concerned?
  11. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    kpa
    killo pascales(sp?)
    eh? /forums/images/graemlins/thumb.gif
    Grant
  12. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Mine's at 279,000km. I get about 40psi cold idle or warm highway. Warm idle was only about 20psi.
    I just switched from 15W40 to SAE 40W and picked up 5psi /forums/images/graemlins/thumb.gif
  13. BiggBlazer
    BiggBlazer Registered Member
    Apr 13, 2002
    18
    Manitoba Canada
    Sorry to correct you,BUT, 400KPa=58psi,200KPa=29psi,275KPa=40psi,550KPa=80psi.
    The formulas are: psi=KPa X .145 and KPa=psi X 6.9
    Hope this helps. /forums/images/graemlins/thumb.gif
  14. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    mine is exactlly the same in all aspects except i got the turbo on it 35 ish idle and 60 on the freeway
