whats your weight?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 77Blazer, Apr 6, 2002.
  1. 77Blazer
    77Blazer 1/2 ton status
    Aug 13, 2001
    197
    Long beach CA
    I just got mine done....
    4000 even!!!
  2. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
    170..oh the truck/forums/images/icons/tongue.gif/forums/images/icons/laugh.gif/forums/images/icons/wink.gif
    My 79 Jimmy weighed 5600, 2 people, half tank, wheeling goods, 4"lift and 35's.
    How does yours weigh 4000??? I want the Willy's to be around 4,000 or just under.
  3. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I gotta call BS...unless you have a fiberglass body on that thing. Where did you weigh it? My 81 Jimmy with soft top, gutted tailgate, 14 bolt FF, and 36" TSL's weighed in at 5700 lbs on a government scale. I can't see your truck being 1700 lbs lighter...
    Rene
  4. UseYourBlinker
    UseYourBlinker 1 ton status
    Jun 7, 2000
    11,117
    Last time I hauled junk to the dumps ...I weighed about 5300. Full tank of gas,Full size spare,and other part's.
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    G.M. '82 preliminary data book;
    Curb-weight *Blazer with gas V-8/4WD, no passangers, as per '82 model year*
    - Total: 4314 lbs.
    - Front: 2304 lbs.
    - Rear: 2010 lbs.
    If thats true and it should be, since it's straight out of G.M.'s manual. Nix the top, and intirior should bring it down to 4000 or so. But, then add lift/tires and add-ons, and your back up to over 4500 lbs.
    Boy, it sure would be nice to trim some fat from these pigs.
    "The only thing I can afford to do is go on a diet"
  6. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Its lookin like mine weighs in more than I thot. Ill have to get it weighed.
  7. MTPockets
    MTPockets 1/2 ton status
    Feb 19, 2000
    502
    Gainesville, Florida
    did you take the body off? that is very low weight for a 3/4 ton k5...
    my 1/2 ton 'k5' weighs 4310#, and i have removed quite a bit of sheet metal. i used chromoly for the cage and an aluminum gas tank to try and reduce the weight even further...the only thing left i could do is add aluminum block and t-case, maybe remove the windshield and replace with lexan.
  8. BorregoK5
    BorregoK5 1/2 ton status
    Sep 7, 2001
    2,457
    San Marcos, Ca USA
    Mine came in at 4450 with the 350ci, 1/2 ton gear, 4" lift, 33's, top on and all the tar paper removed. I've added a 100lb bumper since then and swapped the 350 for a 415, might have picked up a little there.
  9. Dunc03
    Dunc03 1/2 ton status
    May 20, 2001
    157
    Tyler,Texas
    the stock curb weight on my 86 is 4444, but I think that is with the tank empty. Right now its probably around 4600 - 4700 with all the sh** i have in the back.
  10. roostr3269
    roostr3269 1/2 ton status
    Jul 2, 2001
    305
    michigan
    My '72 weighed in at 4600 when i bought it w/ 8" lift, 39's. But that was b4 the 502 and 1 ton axles.
  11. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i would say close to 3 tons for me.
  12. dyeager535
    26,979
    I'm not buying those GM numbers...my truck is pretty basic...no door panels, no dash pad, no carpet, no AC, no emissions(early drivetrain, not that I yank emissions stuff off), 2 core radiator, stock bumpers, 33" tires, stock ralley wheels, half tank gas, spare tire, 350/SM465/NP205, 10bolts. I'm at 5000lbs.
    To cut 1000lbs off of that, I'd have to remove the transfercase and transmission, and I would almost bet that wouldn't even cover that difference. 'Course, not many of us have ever checked to make sure the scale is actually correct : )
    Maybe those GM numbers are based on 2WD variants?
  13. MUDNUTT
    MUDNUTT 1/2 ton status
    Aug 1, 2001
    339
    Mn
    before or after the dougnut??
  14. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Dorian
    Are you refering to the "G.M. data book" quotes?
    I agree, numbers sound a bit light to me too, but it's what G.M. printed.
    Did they swap to 208s in '82? That could have something to do with the weight difference. Smog heads, and some other weight-saveing items too.
    2wd specs are as follows:
    Curb weight:
    front- 1893
    rear- 1958
    total- 3851 (wow!)
    Also, just 'cus I got the book open here.
    Suburban K10
    Front - 2450
    Rear - 2214
    Total - 4664
  15. dyeager535
    26,979
    Yes, I'm referring to the GM numbers. Only speaking for my own truck, I could see how removing the t-case, front driveshaft, and front axle MIGHT reduce 500lbs. (you still gotta have suspension up front, it's gotta weigh at least 100lbs on the 2WD anyways) so maybe a 400 pound weight reduction.
    I've never picked up a 208 so I don't know how it compares to the 205, but IMO, the 205 isn't THAT heavy. Sure, I'm not gonna carry it with one hand, but it's not like it weighs 300lbs. Say it weighs a full 100lbs more than the AL case.
    I also can't vouch for how much the 235/75R15's weigh over the 33x10.5's on my truck now. Say 25lbs per tire more? Thats way more I'm sure, but still, 100lbs.
    Soo..using my rudimentary figures, I come up with 200 less pounds on a stripped K5, stock, compared to mine. That would put me at 4800lbs, still "well" above what GM says they weigh. Removing another 400 pounds would likely require both doors and the tailgate to come off.
    I kind of pride myself on having my truck as light as possible, yet keeping full functionality...for GM to say that the truck is overweight by 600 pounds kind of hurts! : )
    I'm running an SM465 in mine, and I believe in '82 thats what the "stock" transmission was as well, so no weight savings there if so. Don't have my link to the K5 dealer brochure here, but if I did, I would check it. I have one of those preliminary manuals too, they left out 4wd completely...not sure I'd trust those numbers very much, just like I'm not quite sure scales that can weigh vehicles over 50,000 pounds are calibrated often enough to measure 100lb differences accurately....a car with well documented weight ranges got on the same scale, and came out about exactly what it should have been, 3800 lbs.
    So, I won't say the GM numbers are wrong, and I won't say that the scales are wrong, because I have no proof except for the scale weight of my stripped down K5, but apparently, someones numbers are wrong, or GM got real clever on weight reduction in '82, that I missed.
  16. white_knight
    white_knight 1/2 ton status
    Feb 23, 2001
    1,171
    Calgary, Alberta,Canada
    The Knight with the K5 body came in at 6900 lbs. I am going to weigh it with the s-10 body on our first trip out in May. I am really hoping it's about 1000 lbs less. I don't know. We added the one ton frame but stripped the s-10 body. we'll see I guess
  17. POWERMAD
    POWERMAD 1/2 ton status
    Mar 4, 2001
    3,466
    Oregon
    Egads call me tubbo LOL
    When I had the 1/2 ton stuff under it I weighed 5700lbs
    After the swap it went to 6300.
    I pass 2 truck scales on my way to work. And at both the weight was the same.
    My 73 C20 comes in at 5700, I forget what the Burb was but it was kinda hefty.
  18. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Are these Dry weights??? The weight of water/oil/tranny fluid/gear oils add up or maybe the rest of us are just too lazy to scrap all the mud off before going to the scales......
    Mike
  19. tRustyK5
    Jul 23, 2000
    36,173
    1,385
    E-town baby!
    I'd say GM's numbers are way out of whack...I've weighed my truck at three different scales now and it's always been 5700 + or - 100 lbs in the same trim. There is no way my 81 Jimmy is 1400 lbs heavier than a dead stock 82 Blazer.
    Rene
  20. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    I agree, Dorian/Rene. G.M.'s specs are a bit light.
    But it is straight from the guys that built the thing, you would think it would be acurate, why would they lie?
    Maybe it's dry, maybe-not. There isn't enough information given to guess.
    In any case.
    I think a modified 4wd with a blazer frame, drive-train and something resembling a body would tip the scales at no less than 4500 lbs. min.
