Wheatherstripping
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by ShinnyHelmet, Jan 14, 2002.
  1. ShinnyHelmet
    ShinnyHelmet Registered Member
    Nov 1, 2000
    44
    Elk Grove,Ca
    Hey guys....I just purchased all the the weatherstripping for my '71 K5....hopefully I will have time to replace it this week. I got everything except for the front and rear side windows. Any suggestions or advice before I start? Thanks
  2. ChrisM72beast
    ChrisM72beast 1/2 ton status
    May 29, 2001
    214
    Granada Hills CA.
    My only suggestion is that you don't install it in cold weather. The rubber has a tendency of contracting in the cold. Other than that, good luck.
    Chris M.
    <a target="_blank" href=http://www.geocities.com/chrism72beast/beastpage.html>http://www.geocities.com/chrism72beast/beastpage.html</a>
  3. wfahlgren
    wfahlgren 1/2 ton status
    Dec 30, 2000
    157
    Northern California
    where did you buy it? and how much did it cost? what all did you get? thanks
    Jester
  4. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    ALL the weatherstripping? Man, you must be broke!!!
    I remember adding up the stuff just for the hardtop, and that was close to $500.....it's those stupid "door to window" weatherstrips that they really "screw" you on.... something like $100/pr.
    -Greg72
    '72 K5 Blazer - 427BB/TH350/NP205/6" Lift/35x12.50's
    <font color=blue>See it here: </font color=blue><a target="_blank" href=http://coloradok5.com/gallery/albun38>http://coloradok5.com/gallery/albun38</a>
  5. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Yet another reason I ditched the hard top (which I am trying to sell BTY) in favor of a soft top. All the weather stripping I have left is the stuff around the doors which is cheep. Of course I need to fix that lip on the bottom that rusted away if I want to have some place to mount the weather stripping[​IMG]
    '71 Blazer CST w/ a 400sbc, 4" lift, 36" Supper Swampers, and alot of rust
    <a target="_blank" href=http://community.webshots.com/user/triaged>See it Here </a>
  6. skyblazer
    skyblazer 1/2 ton status
    Oct 1, 2000
    209
    Houston, TX
    Happy weatherstripping! I just started the final install on my truck except for the doors. I plan to do this in the next few days. I bougt stuff from LMC. I found out today that LMC sent me the wrong window channel seals with the correct part number on the bag. They suck! Also the right door frame moulding is screwed up. Gotta send it back and try again. Aside from these pitfalls, things fit well and installed easily.
    <P ID="edit"><FONT class="small">Edited by skyblazer on 01/17/02 07:25 AM.</FONT></P>
  7. Wraparound
    Wraparound Registered Member
    Feb 23, 2000
    91
    Sacramento
    Hey guys. If anyones interested I have accululated all of the necessary weatherstripping and I want to sell it now. It's all new and cost a lot of money. I'll sell it for 450.00.
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    check here they were a little cheaper than LMC
    it still really expensive.
    <a target="_blank" href=http://www.gtrestoration.com>www.gtrestoration.com</a>
    click on parts and then put in blazer under the search.
    nathan
  9. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    I have the front and rear door opening rubbers for sale if anyones interested let me know, they are from Lmc the rear ones are GM and the fronts Im not sure.
    $75 shipped.
    Blazin72
    Blazin 72
    1972 K5 350 vortec, 4 inch lift, with nothing else important.
  10. ShinnyHelmet
    Nov 1, 2000
    44
    Elk Grove,Ca
    The weatherstriping i bought i bought from a shop in Roseville called Mikes Truck Shop. All the weatherstriping can be bought at LMC..I just bought mine locally....dont like to give out a creadit info. Top Header strip,door front right and left weatherstrip, door rear right and left,door glass-to-roof weatherstip left and right, right and left rain deflectors and top to rear quarter panel strips, left and right. Just for those peices im up to about $350. The rest is going to have to wait..till later this year. I am in the process of sanding inside the top (had it removed this morning) and will probally paint it with a black/grey "hammered look" pant. The metal strips that are underneath the top (double wall) that hold the bolts in are in neeed of cleaning out, plus I need to add some rivits to reinforce those strips. And I have a bit of fiberglass repair to do on the sides..other than that it should pretty well....I'll try to throw out some pics soon for progress.
