wheel adaptors
Discussion in 'The Garage' started by Bhintz, May 8, 2003.
  1. Bhintz
    Bhintz 1/2 ton status
    Mar 28, 2003
    1,341
    Roswell, Ga
    try a search for this really couldnt find an answer but in echobit 8-6 lug adaptors why is there only 6 holes for the lugs and not 8. /forums/images/graemlins/confused.gif
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    I think 2 of the holes are reused.
    -- Mike
  3. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    It looks to me like you actually have to remove two of the studs. The studs on a 14B are bigger than the studs on a six lug axle and you couldn't use them with many 6 lug wheels, plus the diameter of a circle drawn through the studs is bigger w/ the 8 lug pattern.
    I think the reason is that there is no way to line up the two wheel patterns and use all of the studs.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    I believe it is for the reason stated above. Also, 6 of the 14bff's studs are alot stronger then the 1/2ton studs. (9/16" vs. 7/16")
