wheel and caliper problem
Discussion in 'The Garage' started by badriver19, Dec 27, 2006.
  1. badriver19
    badriver19 Registered Member
    Dec 19, 2006
    71
    Ohio
    i just replaced about $200 dollars worth of brake components on my 10 bolt. i finished everything up and go to put the wheels back on and they hit the new calipers. the new calipers sit about 1/4 inch above the backing plate. i dont understand why they would be different than the old calipers. everything else still lines up and fits right (flex lines, pads, rotors, caliper bolts). its my last obstacle with this front end any help would be appreciated. thanks
  2. sweetk30
    Nov 1, 2004
    25,547
    542
    horseheads , ny 14845
    more info. 6lug 8 lug stock wheels or aftermarket. ? were did you get parts what store? some are 200% junk anymore for parts quality.
  3. Jason4x4
    Jason4x4 1/2 ton status
    Nov 5, 2006
    4,505
    6
    Chandler, AZ
    If it is an 8 lug, and it has 15" wheels, then someone ground down the old calipers, 15" wheels don't fot over the calipers, so they get grinded to fit, you either need to get your core's back and rebuild them and put them back on, or grind the new ones to fit
