wheel base ? has anyone tryed to lengthen thier blazer
Discussion in 'The Garage' started by lgk5, Oct 7, 2002.
  1. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    i was looking for a better departure angle.
    any ideas,or has anyone tryed /forums/images/graemlins/k5.gif
    thanks
  2. muddysub
    Jun 23, 2001
    10,451
    489
    my garage, Henderson, NV
    i think the ORD jimmy is at 110" wheelbase thats like 4" longer than stock.
    for departure angle, bob the rear end /forums/images/graemlins/grin.gif
  3. Blazinaire
    Blazinaire 1/2 ton status
    Mar 17, 2002
    1,262
    Santa Maria, CA
    You can redrill the center pin hole in your leaf springs further back so long as the old hole is between the U-bolts (usually about 1 1/2'') or you can get the same affect and 1'' of lift by using ORD's "zero rate" /forums/images/graemlins/wink.gif. Either method can be used front or rear. After my shackle flip and front springs and shackles were put on I am at 108.5'' which is 2'' longer than stock and I will be moving both front and rear axles to gain another 2.5'' /forums/images/graemlins/grin.gif /forums/images/graemlins/k5.gif
  4. PetaKane
    PetaKane 1/2 ton status
    Apr 17, 2002
    530
    Oklahoma City OK
    I'd like to have a little bit more wheelbase myself and checked into it a bit. Decided I'd only move the back axle because for someone w/out crossover, when you move the front axle forward you have to shorten the draglink which isn't good for already horrid steering geometry.
  5. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Excelent topic!
    Upper Hellderado (B/B) provided a great opritunity to see how a slight change in W/B, changed the "ideal" line, or changed the obsticals.
    The ORD Buggy I think it's close to the stock 106" wheel base
    The ORD Jimmy I think it's around 110" wheel base.
    BadDog's Truggy Somewhere around 112" wheel-base.
    Don't hold me to the wheel-base numbers, Memorys not what it used to be. (who am I kidding, My memorys sucked since day one /forums/images/graemlins/tongue.gif) *I'll change this post if the W/B numbers are not correct*
    The album , kinda helps bring the point home - but not complettly. You just can't get the total "picture" with photos.
    A long Wheel-base can make you look like a pro, but at the same time, it'll hurt you in some cases, not by much tho'.
    From what I've seen so-far, the longer the better - to a point.
    I think about 110" to 112" is about as good as it gets.
    My take on the subject.
  6. Boss
    Boss 1/2 ton status Author
    2,550
    Maryland
    I currently have 110" wheelbase as well. I used custom springs to move the axles forward/back and custom perches for the rear to move it back even further.
    It works for me, but it definately cuts down the turning radius, which sucks in tight trails...
  7. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    I say swap a blazer body onto a pickup or suburban frame. How's that for longer wheelbase!!!!! /forums/images/graemlins/cool.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/burb.gif /forums/images/graemlins/truck.gif
  8. zakk
    zakk 1/2 ton status
    Sep 21, 2001
    4,762
    San Jose CA
    i REALLY want some specs on that ORD Buggy /forums/images/graemlins/thumb.gif
  9. Butch
    Butch 1/2 ton status
    Apr 26, 2000
    1,338
    Austin, TX
    I have mine at 109" and I like it better than it was stock. Keeps the front tires out of the fire wall too. I just drilled the front perches. I built new rear perches that are longer in front of the rear axle to keep it from from wrapping. With this extra length on the perch you can place the rear wherever you want it within reason. The rear perches are 1" taller than stock to compensate for the 60's extra height.
  10. lgk5
    lgk5 1/2 ton status
    Apr 3, 2001
    269
    slc,ut.u.s.a
    glad i wasn't the only one thinking about it!
    but i was thinking about 116-117
    removing the gas tank movining the rear shackel flips
    all the way to the end of the frame and installing and ,or
    building a new front mount.
    the ord shackle flip bracket looks like it would work to keep it level where the frame goes up
    what do you think?
  11. Blazinaire
    Mar 17, 2002
    1,262
    Santa Maria, CA
    Any pics of those rear perches? I want to move the rear axle 2-2 1/2'' back (on top of the 1/2'' that I will need to move it to compensate for the location of the center pin on the furd 57''s) /forums/images/graemlins/k5.gif>>> /forums/images/graemlins/truck.gif
