Wheel base Question/ is a blazer the same as a short box truck ??
Discussion in 'The Garage' started by Supreme70, Dec 3, 2005.
  1. Supreme70
    Supreme70 1/2 ton status
    Jan 19, 2005
    501
    Detroit, Mi
    I was wondering if a short bed chevy was the same as a blazer, im in need of a drive shaft and was wondering if they can be swapped or is the short box truck rear drive shaft longer
  2. 74757685k5
    74757685k5 1/2 ton status
    Nov 13, 2004
    258
    montana
    they are 9in longer .blazer=106.5
    shorty=115
  3. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    nope..
    A shortbed 73-87 Gm is 117.5" wheelbase..K5 Blazer is shorter..many guys use a shortbed driveshaft cut down to fit in lifted K5's..
  4. BlitzK5
    BlitzK5 1/2 ton status
    Jul 29, 2005
    288
    Sherwood Park, Alberta, Canada
    What about the front driveshaft. Are these the same in these trucks or is it longer to?
  5. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    it depends...
    Most front shafts interchange between Blazers and pickups..as long as they have the same tranny and transfer case..for example, a 76 K10 with a NP205/SM465 should have the same front shaft as a 76 Blazer with a SM465/NP205 in it.. an automatic tranny one may fit if it has the NP205,might not..and a NP203 will likely have a different shaft,due to the case itself being longer or shorter..it gets tricky swapping shafts around!..sometimes the "wrong" one will fit a lifted truck,because it was "too long" to fit the stock setup.. :crazy:
