Wheel bearing adjustment.....
Discussion in 'The Garage' started by Zeus33rd, Mar 20, 2002.
  1. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    What is the proper procedure for adjusting wheel bearings? Tighten the first nut how much? The second? I'm constantly lookin for soimethin to tinker with, and this will be my project for tomorrow. /forums/images/icons/laugh.gif
  2. Den
    Den 1/2 ton status
    Jan 12, 2002
    142
    Arkansas
    the second is a locknut isnt it??
  3. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well I have never had much luck with using the torque specs for wheel bearings so I have just done it by "feel" in the past... I spin the wheel while tightening the inner nut...I tighten it until the wheel spins for a revolution or two before it stops...the put in that lock washer looking thing (it can be a biatch to get lined up correctly with the pin on the inner nut /forums/images/icons/crazy.gif)Then crank down the outer lock nut...I torque this one to spec which is quite a bit IIRC (like 100+ ft./lbs.)...
    GL...It's not that hard...
    Chris
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Thanks for the info...Thats more or less how I've been doing it. Ha...Didnt get to it today though...Got busy working on a friends '90 K5. /forums/images/icons/laugh.gif
