Wheel bearing and race ?
Discussion in 'The Garage' started by cegusman, Sep 18, 2003.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    I am swapping hubs on a dana 60 from drw to srw. I did not get bearings with the srw hubs, can't afford new ones right now. The bearings in the drw hub are fairly new, and the races in the srw hubs are in good shape. Is it ok to use the bearings from the drw hubs in the srw hubs, or would I have to move the races over too?
  2. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    TTT
    Somebody has to have an answer
  3. apache7
    apache7 Registered Member
    Sep 18, 2003
    12
    RI
    Most bearing companies will tell you not to interchange the races and bearings. The bearing will actually lap itself to the race in normal use. I do not reccomend it if you want to see it last for awhile.
  4. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Screw it, just put it together. You can buy new bearings later. If you swap the races over you'll definitely be good to go.
    Otherwise, just throw it together...it probably won't hurt anything, but it's a bad practice.
  5. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Thanks, I will probably just use them, I will replace them sooner or later.
