Wheel Bearing exploded view
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Suffergauge, Nov 18, 2002.
  1. Suffergauge
    Suffergauge 1/2 ton status
    Aug 1, 2002
    153
    Olympia, Wa.
    I am attempting to make my efforts "stupid proof" by obtaining an exploded view of the wheel bearing assyembly from the rotor to the hub. My chiltons does not include pictures of the wheel bearings in any of the directions for that area of the blazer, only elploded views of the hubs. I can turn the hell out of a wrench but I want to be positive that this is done right the first time. I know someone has to have something.
    Thanks,
  2. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    Well, I don't have an exploded view but I can tell you whats in there... From the inner wheel bearing out you have:
    -inner wheel bearing
    -outter wheel bearing
    -Wheel bearing nut
    -locking washer
    wheel bearing lock nut
    -locking hub assembly
    thats it...and that is assuming the bearing races are already pressed into the hub/rotor assembly...just make sure you get the torque stting right and it will be good to go..
    the best thing to do is pull it apart and lay all the parts oin order on the floor, then you will know whats in there and in what order..
    Chris
  3. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    Thanks Chris,
    That is maore to go on than I had prior. I would have just laid it all out in order but it all came out a mangled mess, long story. I found the torque specs in my chilton's.
  4. Muley
    Muley 1/2 ton status
    Sep 26, 2002
    364
    Eagle Mountain, UT
    Most of the time you can get a dealership to print you off the exploided view that they use to hunt parts. Then you know what you need.
  5. Rob 85K5
    Rob 85K5 1/2 ton status GMOTM Winner
    1,487
    Pensacola, Florida
    10 bolt front [​IMG]
  6. CooknwithGas
    CooknwithGas 1/2 ton status
    Nov 27, 2001
    332
    Istanbul, Turkey
    Question for ya Rob:
    Will the axle assembly 20, 21, 22 (with the u-joint) slide through the hole in assemly "16" without removing all of the steering linkage?
    If so, that would be GREAT.
    Thanks for your help.
    Scott.
  7. fortcollinsram
    Nov 8, 2001
    2,261
    Fort Collins, CO
    yes, the axle shaft WILL slide through the steering knuckle...all you have to do is take the hub/rotor assembly off and remove the spindle and the axle shaft is free game for coming out...
    Chris
  8. CooknwithGas
    Nov 27, 2001
    332
    Istanbul, Turkey
    Thanks Chris. That is Good news. I have been putting off changing those u-joints because I thought it was a much bigger job and I didn't have the time. I expect something will go wrong, but at least I don't have to get into any ball joints.
  9. Suffergauge
    Aug 1, 2002
    153
    Olympia, Wa.
    Thanks a million Rob. Once I got all the parts it was alot easier to see how it went together. Now I just hace to get back to the part store and replace the oil seal that I destroyed putting everything back together /forums/images/graemlins/angryfire.gif . If you are gonna pull the rotor assy. buy a few of these seals just in case ya pull a stupid like me! I thought it wasn't going on right, smacked it a few times, yanked it off and the goofy spring that holds the seal tight against the axle was a fubar'd.
    Lesson #1 - when you think you are doing it right... read the directions again! /forums/images/graemlins/deal.gif
  10. Rob 85K5
    1,487
    Pensacola, Florida
    If you don't have a seal installer, then use a piece of wood on the seal.
