Wheel bearing installation - Corp14bff
Discussion in 'The Garage' started by Desert Rat, Feb 24, 2003.
  1. Desert Rat
    Desert Rat Fetch the comfy chair
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    I am putting my Corp14ff back together. I went with the A-tron brackets to do the rear disk conversion. Question, when installing the rear wheel bearings, I see no mention of wheel bearing grease in my shop manual. There was no grease on the bearings when I pulled them either. This is on a full floater. I am assuming then that the lubrication for the bearings are derived from the gear oil?
  2. TX Mudder
    TX Mudder 1/2 ton status
    Jul 10, 2000
    2,514
    Houston
    Yes, they are lubed by gear oil.
    When I did mine, I went ahead and greased them pretty well too. Can't hurt.
    -- Mike
  3. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    if you care more then the average mechanic you can top up the gear oil them lift one side at time for a while to allow oil to flow to the hub, then top off the dif again
  4. Desert Rat
    Oct 19, 2002
    16,250
    3
    Tri-Valley, NorCal
    TX Mudder, would that change the properties of your diff fluid as the grease begins to dissolve into it? I wonder how long it would last before it dissappears.
