Wheel bearing or brakes!?!?!?!??
Discussion in 'The Garage' started by NITRO, Mar 26, 2003.
  1. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    after driving for a while(5 miles) it smells like i have an electric fire goin on. it is coming from the drivers side brake. i think that the caliper is just sticking and lettin the brake get held on just enuff to make friction and heat. or, is it the wheel bearing?? thanx for n e help
    NITRO
  2. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    I'd put money on the caliper. Also, I would check it soon. I had one stick and it literally ate right through the capliper, rotor, and was a big mess.
    John
  3. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    ill just change both calipers and call it good. and prolly replace the pads too even though they only have about 250 miles on em
    NITRO
  4. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I'd say caliper also. I just replaced one if mine a few weeks ago. It amazed me how cheap they are, I got a rebuilt one from Autozone for under $20. /forums/images/graemlins/grin.gif
  5. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    Also make sure your rubber brakeline is not plugged. I would have never believed it, but it happened to me. The line was plugged, not letting the fluid pressure release in the caliper. I would say that is a rare problem, but it did happen. Couldnt figure out why it would'nt bleed... danged line was plugged.
    My .02,
    John
  6. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    i just replaced the hoses...but ill check. thanx for the heads up
    NITRO
  7. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    Sounds to me like a bearing If its holden up real hard I can almost guarantee its a bearing and all I can say is DONT DRIVE IT spindles arnt cheap
  8. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    it isnt makin n e noticable drag. i even took the tire off and i can spin it by hand. and it isnt makin n e noise. just after driving i get out and touch a lug nut and they r hotter than hell and so is the caliper. ill just replace calipers and regrind them i guess /forums/images/graemlins/frown.gif
    NITRO
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    One time my caliper was sticking and it was always pull to the right. One night i came home and noticed a smell... looked at the rotor and it was glowing red! /forums/images/graemlins/eek.gif
  10. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    i just got home from cruzin and touched the rotor and it immediately burnt me. so im gettin new calipers tomorrow.
    NITRO
  11. TXsizeK5
    Aug 26, 2001
    2,518
    College Station, TX
    now thats smart. /forums/images/graemlins/rotfl.gif
    goodluck /forums/images/graemlins/thumb.gif
  12. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    It would be a good ideal to have the rotors checked to make sure they haven't warped from all that heat and maybe have them turned if they are still strait.
  13. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    Thats got to suck!
    Now you got a new 454 in and a burnt finger! /forums/images/graemlins/ignore.gif J/K
  14. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    hey J, if i do this tomorrow, ill give ya a ring. that way i can blame it on some1 other than myself when my wheel falls off /forums/images/graemlins/shocked.gif
    NITRO
