Wheel bearing question
Discussion in 'The Garage' started by 1985K20, May 11, 2005.
  1. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    I know i have one or both wheel bearing bad in front pass. side wheel.
    It been like it for quite a long time now, but i had everything cleaned up nice and regreased 3 weeks ago.
    The question is for a week or so now, when i take off in morning or after truck sittin for a while; i hear like a metal to metal sound and then it will go away after i get goin...is this bearing gonna stick on me or wha??
    I was gonna go for a 150 km trip tommorow to get new tires...should i fix that first or im good to make it???
    :confused:
  2. 1985K20
    Jan 11, 2005
    191
    Quebec,Canada
    4x4 3/4 ton by the way :)
  3. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    765
    Granbury, TX
    considering the consequences of having the bearing seize, or worse, i would change it before driving that sort of distance
  4. big jimmy 91
    big jimmy 91 1/2 ton status
    Feb 21, 2004
    639
    Northwestern Ontario Canada
    Pull it apart , inspect and repair as required.
    Causing more damage $$$ is not the thing to do
    I lost the outer bearing on an old 1/2 ton on the hwy. and it cost me the spindle :mad:
    I had a caliper sieze up on the hwy. and set the truck on fire :eek:
  5. short sub
    short sub Registered Member
    Jan 17, 2005
    98
    Sealy Texas
    does the metal to metal noise go away when u hit the brakes??? could be the squeler on the front pads and when the brakes are applied it stops the noise- ive had that happen b4. but i would SURELY tear it down quick and check it
  6. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    I have a 84 similar to yours and to replace the bearings in the front was less then $40.00 for both sides.... So I would say it is cheap piece of mind to change them out if you have any doubts that they might be worn out.... Taking a chance on breaking something, messing up your new tire or even worse causing a accident is not worth it for such a cheap fix...
